POV-Ray : Newsgroups : povray.general : underwater caustics examples Server Time
12 Jan 2026 11:49:28 EST (-0500)
  underwater caustics examples (Message 1 to 7 of 7)
Subject: underwater caustics examples
Date: 20 Sep 2002 09:05:28
Message: <3d8b1d18$1@news.povray.org>
Has anyone got a nice 3.5 file using media and photons that generates nice
ocean/swimming pool floor caustics?
I've been struggling for 3 days and I'm not really getting the results I want.
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: underwater caustics examples - now calling Christoph
Date: 20 Sep 2002 09:18:09
Message: <3d8b2011$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3d8b1d18$1@news.povray.org...
Umm, possibly ignore this - I forgot C.Hormann's tutorial.
Chris - can you supply the pov-code you used to create:
http://www-public.tu-bs.de:8080/~y0013390/pov/water/water33_3b.jpg ?
Date: 20 Sep 2002 10:17:14
Message: <3D8B2DE9.2D0C3859@gmx.de>
The relevant code is:
global_settings {
   photons {
     spacing 0.003
#declare M_Watx =
material {
      color rgbf 1
    finish {
      diffuse 0.0
      ambient 0.0
      reflection {
        0.0, 1.0
        fresnel on
      conserve_energy
      specular 0.4
      roughness 0.003
    normal {
      bozo
      scale 0.15
  interior {
    ior 1.3
box {
  <2.2,2.2,0>, <7.6,8,0>
  material {
    M_Watx
  photons { target refraction on }
  hollow on
And in fact i would have expected you would be able to create something
similar after reading the tutorial - that's what it is for and nearly
every aspect of this code is handled in the text.
Date: 20 Sep 2002 10:51:12
Message: <3d8b35e0$1@news.povray.org>
news:3D8B2DE9.2D0C3859@gmx.de...
Ah - for some reason I thought that particular surface was a iso not just a
normal - I should have looked closer.
Actually I've realised the main problem I've been running into is too low a
photon count. I've switched to using spacing and am getting much better results.
I stupidly assumed that my lack of proper caustics was due to a bad function for
my water surface. Tchh.
Date: 21 Sep 2002 04:04:11
Message: <3d8c27fb$1@news.povray.org>
FWIW and if I'm not mistaken, count and spacing are two ways of
specifying the same thing; either way, X number of photons are
generated, with the only difference being that count lets you set the
number directly while spacing makes POV-Ray determine how many to
generate (not as useful as it sounds, since AFAIK there's no way to
reconcile spacing with any meaningful real-world value, and if you set
spacing too large, POV-Ray won't generate enough photons anyway).
If there's some reason why spacing is better than count, someone please
feel free to point it out...
That said, I find you generally need a LOT of photons to get good
results. If you use count, try something above 100000, and adjust upward
as needed.
-Xplo
Date: 21 Sep 2002 04:17:58
Message: <3D8C2B34.316FCFBB@gmx.de>
The spacing is somehow proportional to how detailed the caustics are (not
precisely of course, this depends on the situation).  This means
specifying spacing is very useful if you shoot photons at a varying number
of objects, you get similar results then.  With a fixed count activating
photons on an additional object totally changes the outcome.
A disadvantage is of course you can't be sure in advance how many photons
will be shot.  Specifying too small spacing can easily lead to a several
hundred MB photons data and hours of parsing time - you have better
control over this aspect with count.
Date: 23 Sep 2002 04:55:35
Message: <3d8ed707$1@news.povray.org>
"Xplo Eristotle" <xpl### [at] infomagicnet> wrote in message
news:3d8c27fb$1@news.povray.org...
<snip>
See Christoph's reply, but basically I keep changing the size of the objects
involved with photons. Count then does not produce consistent results. Also,
with count, you have to often set a very high number, and somehow it's not as
easy to tweak, say, 10000000 as it is to tweak 0.2
