POV-Ray : Newsgroups : povray.general : sphere_sweep woes Server Time
12 Jan 2026 11:49:28 EST (-0500)
  sphere_sweep woes (Message 1 to 10 of 15)
Subject: sphere_sweep woes
Date: 17 Sep 2002 10:37:55
Message: <3d873e43@news.povray.org>
Hi all,
I'm working on a scene with sphere_sweeps, but it renders unusually slow -
there's only 10 points on a cubic spline with just a pigment and the render
drops to 2000 pps. The sphere_sweep seems to be bound incorrectly as well.
Is there anything I can do to speed things up a little? - I've already
adjusted to tolerance to 0.1.
thanks in advance
jim
ps here's the code (cm and mm are just [arbitrary] definitions of units i.e.
cm = 1, mm = 0.1)
#local N=10;
#local Length = 10*cm;
#local Height = 5*mm;
#local Width = 5*mm;
#local y_period = 4;
#local z_period = 4;
#local R1 = 1*mm;
#local R2 = 0.1*mm;
#local i=-1;
sphere_sweep{
    b_spline
    N+1
    #while(i<N)
        <Length/N*i,Height*sin(y_period*pi*i/N),Width*sin(z_period*pi*i/N)>
R1 + (R2-R1)/N*i
        #local i=i+1;
    pigment{White}
    tolerance 0.1
Subject: Re: sphere_sweep woes
Date: 17 Sep 2002 10:45:25
Message: <htfeousevu87ok20jb9u3mo8d49oh6mbns@4ax.com>
On Tue, 17 Sep 2002 15:36:07 +0100, "James Taylor"
I can't promise anything but
http://news.povray.org/d1venucb9u3r431pj99pritqpbddo2fbcb%404ax.com
http://news.povray.org/povray.unofficial.patches/27251/
ABX
Date: 17 Sep 2002 10:47:03
Message: <3D874172.B15F7F1A@pacbell.net>
James Taylor wrote:
> Hi all,
> drops to 2000 pps.
2000 pps is slow ? I have render running right now at 11 ppm!
Ken Tyler
Date: 17 Sep 2002 10:59:00
Message: <3d874334@news.povray.org>
not normally, but this is a test render with no textures and just 1 object -
I was planning on adding focal blur + media etc
jim
Date: 17 Sep 2002 11:25:20
Message: <3d874960@news.povray.org>
James Taylor <jim### [at] blueyondercouk> wrote in message
news:3d873e43@news.povray.org...
That would render in a few seconds with my Cheap_Sweep macro. It makes a csg
sweep object. It is limited when compared to a genuine sphere_sweep, but it
will very quickly make a curvy line.
http://news.povray.org/povray.binaries.images/23308/
http://news.povray.org/povray.binaries.scene-files/23501/
To be honest, I wouldn't use this macro myself anymore because I pretty much
only code meshes now, but it may be the quickest way to get from a to b for
what you are trying to do.
 -Shay
Date: 17 Sep 2002 14:28:34
Message: <3d877452@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote
thanks for the links, Shay - I'll take a look
I might even consider thinking about writing a sphere sweep mesh macro,
although I'm not sure that there would be any benefit in most cases.
jim
Date: 17 Sep 2002 15:02:13
Message: <3d877c35$1@news.povray.org>
news:3d877452@news.povray.org...
Too late, you've already done it! <g>
It would certainly be faster in most cases. I like mesh a lot. I am
currently working on an IRTC entry made entirely out of meshes. My memory
might run out before time does, however. I'm already at 100k vertices (no,
not grass or any other clones) and I've just started.
 -Shay
Date: 17 Sep 2002 16:04:02
Message: <3d878ab2$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3d877c35$1@news.povray.org...
do you plan to publish?
in which case it's time to buy more memory ;)
>...however. I'm already at 100k vertices (no,
go on...give us a clue
jim
Date: 17 Sep 2002 16:18:35
Message: <3d878e1b$1@news.povray.org>
news:3d878ab2$1@news.povray.org...
I haven't made anything, I was just kidding about your wierd sentence.
I'll only say that it will most likely be the only "landscape" entry with no
10k clones, no heightfields, and no naked poser chicks.
 -Shay
Date: 17 Sep 2002 16:24:34
Message: <3d878f82$1@news.povray.org>
Shay <sah### [at] simcopartscom> wrote in message
news:3d878e1b$1@news.povray.org...
Whoops...forgot. I did code a mesh spline sweep once, don't have the code
anymore, however.
http://news.povray.org/povray.binaries.images/23424/
 -Shay
