POV-Ray : Newsgroups : povray.general : PoV can change characters... Server Time
23 May 2026 22:51:27 EDT (-0400)
  PoV can change characters... (Message 1 to 9 of 9)
Subject: PoV can change characters...
Date: 12 Sep 2002 15:14:46
Message: <3d80e7a6@news.povray.org>
A few questions if I may?
  For my present WIP I'm using ac3d a fair bit for some simple modelling, and over
the last couple of days, PoV has changed a few characters or numbers in the ac3d
mesh code. For example, it will change a digit for a $ sign, or it might say that
"...an expected (whatever)... but > found instead", when it *IS* there and should
be there anyway, or the other day it changed 'smooth_triangle' for
'smogth_triangle'.
These aren't really a problem as all I have to do is change back to a previous
digit or letter.
     It's a near 8Mb file so far and my main questions are; how far, and how big
(filesize wise) can I go?
       What can PoV handle?
      I have a feeling that it's the filesize that's doing this?
     My worry is that although the image looks fine at the moment, I fear that
after using some media and possibly other time-intensive code like focal_blur, I
may never get the image to render in the end because also a few days ago PoV
crashed and I lost most of the code I was working on, (it went back about 8
stages!) Luckily, I had already saved a .jpg image of the scene, so I used it for
reference, and the ac3d files weren't affected, so I could still use them.
     Any comments?
     ~Steve~
   PS. Quick tip for any new-users out there who might be creating large filesize
scenes; use 'select all' and copy and paste into a new file and then name the file
using a different name like 'myfile2.pov'. It will save you a lot of hassle if you
encounter problems like I have!  ;)
   PPS. For PoV admin; 'Tips and Tricks' forum?
Subject: Re: PoV can change characters...
Date: 12 Sep 2002 17:49:08
Message: <3d810bd4@news.povray.org>
St. wrote:
>      Any comments?
  I've seen this extact same behavior: when my CPU was burning...
literally. It died some week latter. No kidding! :(
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 12 Sep 2002 18:11:55
Message: <3d81112b@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3d810bd4@news.povray.org...
> St. wrote:
> >      Any comments?
   I believe you, honest!  :)  But I think I know my kit now, and it ain't gonna
happen Jaime, everything else works fine, no problems.
 However, if you don't see me around in a couple of weeks time, please send out a
search party...  I'll be over there somewhere   >>>    frantically waving a PoV
flag...   ;)
     ~Steve~
> La Persistencia de la Ignorancia
Date: 12 Sep 2002 20:34:46
Message: <3d8132a6@news.povray.org>
Are you overclocking your CPU?  I have seen such glitches in those cases.
Cheers!
Chip Shults
Date: 12 Sep 2002 20:59:05
Message: <3D813954.88F1881A@pacbell.net>
> 'smogth_triangle'.
I used to have that problem with the POV-Ray v3.0 editor but I have never seen
this happen with the CodeMax editor released with POV-Ray v3.1. I've loaded
100mb files without problems in the CodeMax editor so I know file size is not
to blame. It might be a memory problem on your machine or perhaps like the
others have said your processor is having problems.
When I had problems with the v3.0 editor I would close the program after every
3 saves and that kept me from having the character replacement problem you
described above. This is just a bandaid for the real problem though, whatever
that is.
Ken Tyler
Date: 13 Sep 2002 00:05:06
Message: <3d8163f2@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3D813954.88F1881A@pacbell.net...
> "St." wrote:
 >....or the other day it changed 'smooth_triangle' for 'smogth_triangle'.
> that is.
      Thanks for that Ken, I think you may be right with the memory. I remember a
couple of years ago I was getting little glitches in other programmes until I
upped from a 64Mb stick and added another 128Mb alongside it. That seemed to cure
all problems back then.
    ~Steve~
> Ken Tyler
Date: 13 Sep 2002 00:05:07
Message: <3d8163f3$1@news.povray.org>
"Sir Charles W. Shults III" <aic### [at] cflrrcom> wrote in message
news:3d8132a6@news.povray.org...
       No, it's running at what it should be, 600Mhz, 192Mb RAM. I think it's a
memory issue.
       ~Steve~
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
Date: 13 Sep 2002 19:53:46
Message: <3d827a8a$1@news.povray.org>
Try docmem:
http://www.simmtester.com/PAGE/products/doc/docinfo.asp
It's free and will allow you to thoroughly test your memory.  When I have
your kind of problem, docmem is waht I use to ferret out the cause.
Jim
Subject: Re: PoV ***CANNOT*** change characters, it's my memory that's failing me... Pardon? ;)
Date: 14 Sep 2002 14:13:21
Message: <3d837c41@news.povray.org>
"Jim Kress" <nos### [at] kressworkscom> wrote in message
news:3d827a8a$1@news.povray.org...
> Try docmem:
Jim, passed over to O-T.
     ~Steve~
> Jim
