POV-Ray : Newsgroups : povray.general : isosurface woes Server Time
29 Dec 2025 00:30:35 EST (-0500)
  isosurface woes (Message 1 to 3 of 3)
Subject: isosurface woes
Date: 8 Sep 2002 17:45:25
Message: <3d7bc4f5@news.povray.org>
Hi all
I've just started playing around with isosurfaces, only without much
success.
Here's a snippet of my code:
#local round = 0.2;
isosurface {
    function{f_superellipsoid(x,y,z, round, round)}
    contained_by { box { -1, 1 } }
    pigment{White}
I would expect this to produce a round box, but all I see is the container
box with some artefacts.
My aim to produce a round box as would appear if using the superellipsiod
primitive - I'm using an isosurface though because I want to later deform it
with a noise function.
I'm guessing there's a simple solution I've overlooked in the manual.
thanks in advance
jim
Subject: Re: isosurface woes
Date: 8 Sep 2002 18:08:56
Message: <chrishuff-E756DB.18082308092002@netplex.aussie.org>
In article <3d7bc4f5@news.povray.org>,
I can think of two possibilities:
1: the shape is simply bigger than the container. Try making the
container bigger.
2: the superellipsoid is inside-out for some reason...use "open" or
modify the function.
http://tag.povray.org/
Date: 8 Sep 2002 18:14:00
Message: <3d7bcba8@news.povray.org>
Thanks - I think it was inside out - I changed the function to
    -f_superellipsoid(x,y,z, round, round)
    |----mulitiplied the thing by -1
and I get the 'proper' result
jim
