POV-Ray : Newsgroups : povray.general : Shortest Code Contest, Round Two, display and voting page Server Time
14 Jun 2026 21:38:02 EDT (-0400)
  Shortest Code Contest, Round Two, display and voting page (Message 1 to 10 of 23)
Subject: Shortest Code Contest, Round Two, display and voting page
Date: 2 Jul 2002 13:51:36
Message: <3d21e828@news.povray.org>
. . .  is now open.
http://10best.raytrace.com/short2/shortvote2.html
Votes accepted until July 17th, 2002.
Thanks to Mr.  W3 ABX Skiba for help in rendering (and to numerous others
who offered it earlier).
Subject: Re: Shortest Code Contest, Round Two, display and voting page
Date: 2 Jul 2002 15:18:32
Message: <3d21fc88@news.povray.org>
Greg M. Johnson <gregj;-)565### [at] aolco:-(m> wrote:
> . . .  is now open.
  Would it be possible that next time you could use some smarter program
to reduce the size of the images (for the thumbnails)? It looks like the
program you used reduced the images simply by dropping rows and columns
of pixels, which is not really nice.
  The images with most little details suffer the most from this. They end
up looking like random noise.
Date: 2 Jul 2002 17:19:42
Message: <3D2218BB.1010503@videotron.ca>
Greg wrote:
> . . .  is now open.
Hmm...  You might want to correct the typo on the viewing page:
"    * The voting period will close July 176h, 2002, at midnight (time
stamp on your email)."
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 3 Jul 2002 01:57:46
Message: <n745iu0famk2im741ntethqccuehme639s@4ax.com>
> > . . .  is now open.
You are right. I missed this during conversion. I had no scope on thubnail
smoothing since I had already set Lanczos filter in my IrfanView. Looks like
batch converting in IrfanView has no setup for resize filter so I assume it
should get the same as for normal converting. But it doasn't. Greg I will
upload zip with correct thubnails after ten minutes at the same place as
previously.
ABX
Date: 3 Jul 2002 18:25:49
Message: <3d2379ed@news.povray.org>
Should be fixed in an hour or so.
Q: are the 800's the best they can be??
Date: 3 Jul 2002 18:41:52
Message: <3d237db0@news.povray.org>
  I would have made my images a LOT better, but with only 500 bytes available
it's not easy... ;)
Date: 3 Jul 2002 18:59:02
Message: <3d2381b6@news.povray.org>
Errr,  I mean is the render-quality of the 800's ok: I don't mean technical
merit and all that.............
Date: 3 Jul 2002 19:13:43
Message: <3d238527@news.povray.org>
  I knew that.
Date: 6 Jul 2002 18:32:16
Message: <3d276ff0$1@news.povray.org>
Aaah.  Some versions of IE will squish an image down to fit the browser
window if they are larger than the size it wants to give them.  The
squishing is apparently "AA 0.0."
Date: 6 Jul 2002 21:31:47
Message: <3d279a03@news.povray.org>
  Which is, of course, another braindead idea from MS.
  I suppose that it can be turned off...
