POV-Ray : Newsgroups : povray.general : Scripting guidance Server Time
13 Jan 2026 03:11:52 EST (-0500)
  Scripting guidance (Message 1 to 10 of 12)
Subject: Scripting guidance
Date: 19 Jun 2002 07:36:57
Message: <3d106cd9@news.povray.org>
Hi All
I was wondering about what is good form in regards to writing pov scripts
(do you call them scripts?). With lots of objects, especially of type mesh,
cameras, lights, textures etc, I can image that pov fies get really big. Any
clues somewhere on how a good pov file could be laid out to make development
and maintenance easier?
Also, I'm working on animations, and have discovered some of the animation
options (Final_Frame etc). It seems that I have to put these in my
povray.ini file to work. However whenever I want to switch from generating
all images of the animation sequence, to say, only one image, I have to edit
this file and change the value of Final_Frame to 1. Same is true if I want
to switch on or off writing of rendered image output files in a working
session. Is there any easier way to do this than editing povray.ini? Can
these controls be placed in the pov script I am working on. It wasn't clear
to me how to do this from the documentation.
Thanks for any guidance.
Be Well and Happy Always
Chris
Subject: Re: Scripting guidance
Date: 19 Jun 2002 09:42:51
Message: <3D1089FA.8000905@b0n541.net>
You can separate the textures, meshes and other objects into different
files with the extension .inc (this is not required, but easier to
recognize which is the global POV-Ray-File). Use the #declare function
to give them a name:
#declare MyBestTextureIEverMade = texture
   pigment
Then make a global scene and include all necessary files with #include
"filename.inc". Now you can use your defined textures, meshes and what ever.
e.g. a Mesh-Object
#include "mymeshes.inc"
#include "mytextures.inc"
object
   TheBigMesh
   texture
Hope that helps...
So long,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 19 Jun 2002 11:16:34
Message: <Xns9232739086B32mrartchesapeakenet@204.213.191.226>
Chris Friedl scribis news:3d106cd9@news.povray.org:
> I can image that pov files get really big. Any
> development and maintenance easier?
I tend to model smaller parts of whatever it is I
am working on and save each small part in its own
.inc file.
An example:
// park scene
#include "bench.inc" object {bench rotate <,,> translate <,,>.....}
#include "trees.inc" object {Tree35 ......}
#include "outdoorlamps.inc"object {StreetLamp2 .....}
camera{...}
In this way I can see the overall layout of the scene without
a lot of clutter to distract me.
I also have a setup for each file that allowes me to render each
peice or object in its .inc file and still use the .inc file
without modification in the main scene file.
An example:
#include "Colors.inc"
#include "Global_Settings.inc"
#include "FileInUse.inc"
// development code goes here.
#if	(FileInUse=0)
	camera		{.....}
	#include	"Sun.inc"	object{Sun scale 1 rotate <+45,-15,0>}
	object		{ Jayhawk rotate y*0} //Jayhawk is a ship in Traveller
#include "FileNotInUse.inc"
FileInUse.inc is
#ifndef(FileInUse)#declare FileInUse=0;
#else #declare FileInUse=FileInUse+1;
FileNotInUse.inc is
#declare FileInUse=FileInUse-1;
As you can see, if the inc file is not included but rendered
directly,the camera and scene building statements at the bottom
are used.
If the .inc file IS included in another scene file that uses
this same setup, the camera and scene setup at the bottom is
ignored and it is up to the main scene file to define the camera
and such.
In this way I can work on one small part of an object or scene
without having to work on one large file.
Gis poste, Arto.
Date: 19 Jun 2002 17:48:53
Message: <3D10FC53.EC10D11@hotmail.com>
Chris Friedl wrote:
> Hi All
> scripts (do you call them scripts?). With lots of objects,
> especially of type mesh, cameras, lights, textures etc, I can image
> that pov fies get really big. Any clues somewhere on how a good pov
> file could be laid out to make development and maintenance easier?
Put each model in a separate .INC file.
Put your most commonly used textures into one .INC file.
Divide each major project into functional lines.  For instance, I
am now working on my 16th Rusty animation.  I have the following
files to accomplish this:
r#16.pov -- the main file
r#16_s01.inc -- a file defining the scenery for several shots
r#16_s02.inc -- more scenery files
r#16_c01.inc -- a file containing the camera
r#16_l01.inc -- a file defining the lighting
r#16_p01.inc -- a file defining the props in each shot
r#16_r01.inc -- this file places and animates the robots
r#16_t01.inc -- a file defining the subtitling, camera fades, etc.
r#16.pov contains code that determines which shot is being rendered,
based on the clock value; the other files have switch statements
to control which scenery items get placed.
> animation options (Final_Frame etc). It seems that I have to put
> these in my povray.ini file to work. However whenever I want to
> switch from generating all images of the animation sequence, to
> say, only one image, I have to edit this file and change the value
> of Final_Frame to 1. Same is true if I want to switch on or off
> writing of rendered image output files in a working session. Is
Copy povray.ini to another file, such as test.ini, still.ini,
final.ini, etc.  Edit them to do what you want.  Run the one that's
set up to do what you want.
John
Date: 19 Jun 2002 18:07:34
Message: <3d1100a6$1@news.povray.org>
I'd recommend using proper indention, put comments before each block of
code, and use descriptive variable names but not with very long names,
instead write additional comments to describe their use.
Some people write a lot of empty lines, or nearly empty lines, but I don't
recommend you do that. On the other hand, lines can become too crowded with
keywords or several brackets. Try to find a golden 'middle way'.. (Is that
proper english?)
I also recommend that you try to declare many variables for your objects,
when ever possible. It's easier to change the overall size, thickness or
roundness for a complex object ,when it was build around a set of variables,
instead of putting the numbers directly into the code.
Another advice would be to declare the variables in 'clusters'.. I mean,
instead of having them spread around the script, collect them next to each
other.. Then it's easier to find them later.. Similar with #include files:
put them in clusters when possible.
Enough now.  :o)
Hugo
Date: 19 Jun 2002 20:18:08
Message: <3d111f40$1@news.povray.org>
"Chris Friedl" <cfr### [at] bigpondnetau> wrote in message
news:3d106cd9@news.povray.org...
edit
clear
Some of these could be accomplished by editing the POV QuickRes.ini file.
It isn't limited to resolution settings. I've customized mine to include
animation
settings for rendering stereo pairs. For example:
[800x600, AA 0.3]
Width=800
Height=600
Antialias=On
Antialias_Threshold=0.3
[Stereo 800x600]
Initial_Frame = 1
Final_Frame = 2
Initial_Clock = 0
Final_Clock = 1
Cyclic_Animation = off
Pause_when_Done = off
+w800 +h600
AntiAlias=On
I can chose to render just one image or a stereo pair by selecting
the corresponding "quickres" setting. The animation values result in
two images rendered, within the scene script file the clock value
moves the camera to give two view for stereo effect.
This is the camera definition that makes use of clock value:
//----- S t e r e o  C a m e r a -------\\
#declare dist=15;
#declare Camx=dist/60;
#if (clock)
  #declare Camx=-(dist/60);
camera {location <Camx,-0.5, -15> look_at <Camx,0,0>
 You can do a lot with a customized quickres.ini file.
Harold
Date: 19 Jun 2002 21:29:12
Message: <3d112fe8$1@news.povray.org>
Sorry, can you clarify that a bit. I want to set up a batch of animations to
render during my vacation. Each scene file will be in a separate folder and
will need its own start and end frame, plus most importantly, its own clock
setting. I tried copying povray.ini to each folder, but it still rendered
using the default povray.ini in the Renderer folder
So how can I set up numerous ini files, one per folder, then run a Queue so
that each scene renders with its own settings? Do I need to add something to
the actual scene? I am using the GUI under Windows.
Thanks
D
"Harold Baize" <bai### [at] itsaucsfedu> wrote in message
news:3d111f40$1@news.povray.org...
animation
generating
> edit
want
> clear
> animation
> [800x600, AA 0.3]
> Width=800
> Height=600
> Antialias=On
> [Stereo 800x600]
> Initial_Frame = 1
> Final_Frame = 2
> Initial_Clock = 0
> Final_Clock = 1
> +w800 +h600
> AntiAlias=On
> #declare dist=15;
> #if (clock)
> #end
> Harold
Date: 19 Jun 2002 23:09:43
Message: <3d114777@news.povray.org>
That could be accomplished with an old fashioned
DOS batch file. Maybe someone else can describe
how to do it within the Windows GUI.
Harold
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3d112fe8$1@news.povray.org...
to
and
clock
so
to
> Thanks
> D
> animation
> generating
to
> > edit
> want
working
Can
> > clear
file.
> > animation
> > [800x600, AA 0.3]
> > Width=800
> > Height=600
> > Antialias=On
> > [Stereo 800x600]
> > Initial_Frame = 1
> > Final_Frame = 2
> > Initial_Clock = 0
> > Final_Clock = 1
> > +w800 +h600
> > AntiAlias=On
> > #declare dist=15;
> > #if (clock)
> > #end
> > Harold
Date: 20 Jun 2002 03:17:58
Message: <3d1181a6@news.povray.org>
news:3d114777@news.povray.org...
Sure :-) Use the ini files in the Queue instead of the pov files, each with
a Input_File_Name= corresponding to the pov file. Of course that means you
need a ini for every pov, unless someone has another idea.
Oh yeah, Chris Cason had made it possible to render a list of pov files
(Insert Menu bitmaps) from within a single ini by using numbered block
sections. I thought I knew how to do that but I recall never getting it to
work and I think Chris coaxed POV-Ray to count through the settings blocks
internally through the program. Having checked it out again here I could
only get the first section of the ini to be seen if it is also set in the
Ini dialog. If it isn't, the 'object.pov not found' error happens.
bob h
animations
> to
> and
> clock
rendered
> so
something
> to
> > Thanks
> > D
> > animation
> > generating
> to
> > > edit
I
> > want
> working
> Can
wasn't
> > > clear
> file.
include
> > > animation
> > > [800x600, AA 0.3]
> > > Width=800
> > > Height=600
> > > Antialias=On
> > > [Stereo 800x600]
> > > Initial_Frame = 1
> > > Final_Frame = 2
> > > Initial_Clock = 0
> > > Final_Clock = 1
> > > +w800 +h600
> > > AntiAlias=On
> > > #declare dist=15;
> > > #if (clock)
> > > #end
> > > Harold
Date: 20 Jun 2002 14:28:19
Message: <3d121ec3$1@news.povray.org>
"bob h" <omn### [at] charternet> wrote in message
news:3d1181a6@news.povray.org...
with
Bob,
Where do I find the Queue in MS Windows?
HB
