POV-Ray : Newsgroups : povray.general : Ridged Multifractals Server Time
14 Jun 2026 23:23:55 EDT (-0400)
  Ridged Multifractals (Message 1 to 8 of 8)
Subject: Ridged Multifractals
Date: 17 May 2002 07:36:07
Message: <3ce4eb27@news.povray.org>
Hi there.
[first post in a very long time]
I've just started trying out the f_ridged_mf function to create a
landscape with, but I have a slow computer (p233) and figuring out a
decent set of parameters by trial-and-error is beyond my limited
patience.  Has anyone got a "ready-made" isosurface they could post that
demonstrates good parameters and scaling to create a landscape with?
I'm thinking something along the lines of the one in Gilles's recent
masterpiece - ie a mountainous desert region.
Thanks in advance.
Andrew
Subject: Re: Ridged Multifractals
Date: 17 May 2002 08:11:35
Message: <3ce4f377@news.povray.org>
3ce4eb27@news.povray.org...
Here are the two I used :
// foreground
// the 0.15... at the end makes the terrain flatten in the z direction
isosurface{
    function {y-f_ridged_mf( x*0.5, y*0.5, z*0.5, 1, 2, 9, -1.3,
3,3 )*0.15*(-z+50)/80}
    max_gradient 2.4
    contained_by{box{<-2000,-0.01,-30>,<2000,1,50>}}
    translate y*-0.4
// mountain
// the (1-...) at the end makes the terrain flatten in the -x and -z
direction
#declare RESOLUTION = 100;
//#declare RESOLUTION = 1000;
height_field {
    function RESOLUTION,RESOLUTION {
        f_ridged_mf( z*2, y*2, x*2, 1, 2, 9, -0.5,
3,3 )*0.8*(1-y*0.98)*(x+0.2)
    translate <-0.5,0,0>
    scale <120,5,60>
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 17 May 2002 09:48:27
Message: <3ce50a2b@news.povray.org>
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3ce4f377@news.povray.org...
<snip>
I've not yet played with any of the h-f/function stuff in 3.5.
Can anyone give a quick explanation as to what they're for? For example, in
Gilles's post, why use a hf with the ridged mf rather than just using the ridged
mf directly?
I know, I know - I could read the docs and test things out, but I thought that a
discussion on this might be of general interest anyway.
Date: 17 May 2002 09:55:01
Message: <3ce50bb5$1@news.povray.org>
> // foreground
> isosurface{
>     max_gradient 2.4
>     translate y*-0.4
> // mountain
> direction
> height_field {
>     scale <120,5,60>
> - POV-Ray and Poser computer images
> - Posters
Thanks Gilles!  That's just the kind of thing I'm after.
Date: 17 May 2002 09:57:43
Message: <3ce50c57@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3ce50a2b@news.povray.org...
> <snip>
example, in
the ridged
> mf directly?
thought that a
Not that I've tried it out yet, but I think that the height field would
render faster than an isosurface, as it is precalculated at a fixed
resolution.  That way, when it traces, the surface doesn't have to be
calculated.
Date: 17 May 2002 10:08:04
Message: <3CE50EC8.BC3F19C1@gmx.de>
> mf directly?
It is faster usually.  For a direct comparison see the 'landscape.pov'
demo scene from POV-Ray 3.5.
It should be mentioned that Gilles' code does not use the classical
'hf-style' function which would have constant gradient in vertical
direction:
function {y-f_ridged_mf( x, 0, z, ...
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 17 May 2002 12:47:43
Message: <3ce5342f$1@news.povray.org>
in
ridged
> mf directly?
Speed was already mentioned but in this case it was also the ability to use
a low res version during the tests. And I wanted to test the feature in a
real image too.
G.
- Posters
Date: 17 May 2002 13:16:00
Message: <3ce53ad0$1@news.povray.org>
3CE50EC8.BC3F19C1@gmx.de...
> direction:
In fact, the height_field example can also be simplified as the z coordinate
is not used.
height_field {
      function 100,100 {
        f_ridged_mf( x, y, 0, 1, 2, 9, -0.5, 3,3 )*0.5
G.
- Posters
