POV-Ray : Newsgroups : povray.general : Bitmaps for heightfields Server Time
23 Apr 2026 03:10:55 EDT (-0400)
  Bitmaps for heightfields (Message 1 to 7 of 7)
Subject: Bitmaps for heightfields
Date: 26 Apr 2002 14:21:21
Message: <3cc99aa1$1@news.povray.org>
I am using M$ Paint to create a bitmap and then Photoshop to do a Gausian
Blur on this image to smooth everything out so as I have some nice hills.  I
have no problem with the x and z resolutions (6000*6000 is probally a bit
over the top for my purposes, but what the hell) but the y resolution is
limited to 256 levels (8 bit greyscale).  I would much prefer this to be
16bit greyscale but Photoshop won't do the Gausian Blur (or any blurs for
that matter) when I set this pixel depth to this.
Does anyone have a solution for my problem?
Thanks Alot, Aly.
Subject: Re: Bitmaps for heightfields
Date: 26 Apr 2002 14:33:08
Message: <3cc99d64@news.povray.org>
  If you don't have any special reason to draw it by hand, you can create
nice height_fields directly with another POV-Ray scene, or internally with
the beta version and the function image pattern.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 26 Apr 2002 14:57:40
Message: <3cc9a324@news.povray.org>
----- Original Message -----
From: "Jaime Vives Piqueres" <jai### [at] ignoranciaorg>
Newsgroups: povray.general
Sent: Friday, April 26, 2002 7:36 PM
The only reason to draw it by hand is it's so much easier to have my hills
and lake where I want them.
Date: 26 Apr 2002 15:16:39
Message: <3cc9a797@news.povray.org>
  Yes, if you want precise control you need a paint program. Anyhow, this
can also be done to some extent with another scene, using an old trick with
spotlights. See crater.pov on the sexample scenes.
Date: 26 Apr 2002 15:41:52
Message: <3CC9AD7F.FA412897@bellsouth.net>
> have my hills and lake where I want them.
How to get really high-quality heightfields:  don't use greyscale.
Use colour.  Your lowest elevation is still &H000000 and
highest is still &HFFFFFF, but you can step through all
16777215 values and have a much smoother heightfield.
Your Freudian slip is showing.
Tim Cook
http://personal.lig.bellsouth.net/lig/z/9/z993126
Version: 3.12
Date: 26 Apr 2002 15:42:05
Message: <3cc9ad8d$1@news.povray.org>
Try *lowering* the resolution. If the resolution is low enough, then the
separations between levels will be less obvious. Of course, you might not be
able to afford too low of a resolution. I don't really know what the
solution is; I've never gotten a hight field to really look good.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 26 Apr 2002 16:24:15
Message: <3cc9b76f$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3cc9a797@news.povray.org...
<snip>
Sexample scenes? They sound good!! Where do I download them?
Andy Cocker
