POV-Ray : Newsgroups : povray.general : Heightfield and imagemap question Server Time
30 Mar 2026 05:22:17 EDT (-0400)
  Heightfield and imagemap question (Message 1 to 6 of 6)
Subject: Heightfield and imagemap question
Date: 15 Apr 2002 16:16:21
Message: <3cbb3515$1@news.povray.org>
Stupid Question Alert!!! ;-)
Why is it when I assign an imagemap material to a heightfield (or a side of
a cube, etc.) the imagemap is tiled four times? If I add the 'once'
parameter it will only fill 1/4 of the heightfield.
How do I get the entire imagemap to cover the entire heightfield only once?
(BTW, both the image and the heightfield are square in the X and Y axis, if
that makes a difference.)
Mike
Subject: Re: Heightfield and imagemap question
Date: 15 Apr 2002 16:45:18
Message: <3cbb3bde@news.povray.org>
Read the documentation about the 'scale' transformation.
Date: 15 Apr 2002 17:51:05
Message: <3cbb4b49$1@news.povray.org>
Okay stupid questions are also accepted, don't worry. How did you scale your
heightfield? Simply scale your texture in the same way, or apply the texture
*before* you scale the heightfield.
Hope this helps.  ;o)
Hugo
Date: 15 Apr 2002 18:03:02
Message: <3CBB4E0F.B55F24F8@aol.com>
You have to understand how height_fields and image maps work. The height_field
is created on a square centered at <0,0,0>, proceeding to <1,0,1>. The
image_map is created at <0,0,0>, and proceeds to <1,1,0>. The first thing you
have to do in both cases is to center the height_field by translating by
<-.5,0,-.5>, and the image_map by translating it by <-.5,-.5,0>. This should be
done before scaling. From there, it is a simple matter of rotating the
image_map x*90 to make it "lay down" onto the height_field. Hope this helps.
Date: 15 Apr 2002 19:09:01
Message: <3cbb5d8d@news.povray.org>
Hugo wrote in message <3cbb4b49$1@news.povray.org>...
>How did you scale your heightfield?
First I should mention I'm using Moray...
I scaled the heightfield to 20, 20, 0.1.
Maybe I'm missing something (well, obviously I am) but no
matter how I scale or translate the material or heightfield it
always renders the imagemap in quarters on the heightfield.
>or apply the texture *before* you scale the heightfield.
Not sure I understand.
Mike
Date: 16 Apr 2002 01:09:35
Message: <3cbbb20f@news.povray.org>
Michael Smith wrote in message <3cbb5d8d@news.povray.org>...
There's the problem.  I'm not a regular Moray user, but I'm fairly sure that
Moray applies a "scale 2 translate <-1,-1,-1>" to any heightfield when it is
created.  To get your image to map properly, you'll need to apply the same
transformation to it.
Mark
The Universe is expanding.
The budget for its exploration is shrinking.
