POV-Ray : Newsgroups : povray.general : alpha transparency help Server Time
27 Nov 2025 12:51:25 EST (-0500)
  alpha transparency help (Message 1 to 8 of 8)
Subject: alpha transparency help
Date: 4 Apr 2002 14:27:23
Message: <3caca91b@news.povray.org>
Ok I made a pic with an all white background by making the actual background
white. I also added an infinte plane that is white with an ambient of .4 as
a floor. I did this because I wanted the objects I placed in the scene to
have shadows on a floor but still have the floor indistinguishable from the
sky. My first problem is that ambient .4 really lightens up the shadows but
if I lower the ambient the horizon becomes visible. My other problem is I
want to make this pic alpha transparent. When I do so the white background
becomes transparent but the floor doesn't. Is there a way I can give the
floor a no_image tag or something similar but still let shadows be cast on
it.
Thanks
Corey
Subject: Re: alpha transparency help
Date: 4 Apr 2002 15:08:17
Message: <chrishuff-1C5ADB.15093504042002@netplex.aussie.org>
In article <3caca91b@news.povray.org>,
> it.
That would be meaningless, of course...you can't have shadows on nothing.
There are several simple ways to solve this, the easiest would be: Just
don't use an infinite plane. Use a box or something just large enough
for the shadows, but not big enough for light fading to make a
difference. Using a diffuse slightly larger than 1 would help make the
edge invisible.
Date: 4 Apr 2002 15:19:58
Message: <3cacb56e@news.povray.org>
AFAIK no-one has yet invented a feasible trick which would work always
so that you could get semi-transparent dark shadows without anything else.
Date: 4 Apr 2002 15:50:00
Message: <64epau09jm2je8i8bofek3tcrsg536lu8q@4ax.com>
On Thu, 4 Apr 2002 14:32:26 -0500, "Corey Woodworth" <cdw### [at] mpinetnet> wrote:
> it.
Try this:
1. Create plane/background as object in variable.
2. Create your model as object in variable.
3. Trace grid of rays:
  - resolution of grid (grid_res) is small becouse makes smoothness/accuracy
    of edges in shadow
  - whole grid contains all vertices of bounding box of your model
  - everyt ray start from light_source and goes along grid
  - test intersection of ray with model
4. For every succesful intersection in point 3 test intersection of the same
    ray with your background object
5. For every succesful intersection in point 4 create disc with
  - center at intersection point
  - normal at intersection point
  - radius = grid_res / sqrt(2)
  - material as in background object
Tell me if it works, I never tested.
ABX
Date: 4 Apr 2002 15:56:15
Message: <3cacbdef@news.povray.org>
> Try this:
Oh ... ;o)  that looks complex compared to my idea: Leave ambient and
instead set an extremely high specular or phong reflection. At some point
it's all gonna be white, except the shadows will still be shadows!
Best wishes,
Hugo
Date: 4 Apr 2002 16:31:06
Message: <chrishuff-3ABE17.16322304042002@netplex.aussie.org>
In article <3cacbdef@news.povray.org>, "Hugo" <hua### [at] post3teledk>
Just set brilliance to 0, and there won't be any shading done at all, so
no more horizon problems. Or just don't use an infinite plane...no
horizon at all.
Date: 4 Apr 2002 17:48:56
Message: <3cacd858@news.povray.org>
It just came to me..
white plane
no_image objects
orthographic camera above the scene
save the image and image_map it onto a box, make white transparent
remove plane, no_image and move camera to original position.
Now the image_map would be the shadows right?
Haven't tried it out, but I imagine it could do the trick?
If not, the white box is the way..
Peter
http://hertel.no/peter
background
as
the
but
> it.
> Thanks
> Corey
Date: 5 Apr 2002 16:31:32
Message: <3cae17b4$1@news.povray.org>
I figured out a way to do it but it is all post processing. First I make a
pic with no plane and then a 2nd one with the plane. I combine the
transparent section of the first pic with the rest of the 2nd pic to make an
alpha channel. Works nice but I gotta render twice.
Corey
