POV-Ray : Newsgroups : povray.general : Volumetric media fog... Server Time
23 Apr 2026 06:50:45 EDT (-0400)
  Volumetric media fog... (Message 1 to 2 of 2)
Subject: Volumetric media fog...
Date: 1 Apr 2002 12:30:17
Message: <3ca89929@news.povray.org>
Can somebody can help me to simulate an "Atmospheric blue media" like
Terragen does (for example) this test scene following use the fog to
simulate it but I think I can does it better with medias... the fog is too
simple and the far spheres looks to be erased by the fog, I just want to
make them blue-er like when you look at far mountains at the morning...
// MEDIA test... without media so !
background {color rgb <0.1, 0.1, 0.8>}
light_source {<30, -30, 100> color rgb <1.0, 1.0, 0.9>
area_light <-10,-10,-10><10,10,10>,5,5
adaptive 2
jitter
circular
orient
plane {z,0 texture {pigment {color rgb <1.0, 1.0, 0.9>}}}
camera {location <0, 0, 1.7> look_at <0.0, 50.0, 1.0>}
#declare yy = 0;
#while (yy < 31)
 sphere {<3, yy*8, 1>1 pigment {color rgb <0.7, 0.1, 0.2>}}
 sphere {<-3, yy*8, 1>1 pigment {color rgb <0.7, 0.1, 0.2>}}
 #declare yy = yy + 1;
fog {
  fog_type 1
  distance 150
  color rgb <0.5, 0.5, 0.8>
Subject: Re: Volumetric media fog...
Date: 1 Apr 2002 20:01:14
Message: <3ca902da@news.povray.org>
"_Light_Beam_" <fac### [at] aolcom> wrote in message
news:3ca89929@news.povray.org...
> Terragen does
---snip---
> the fog is too
Easiest way is to use transmit in your fog color.  media is still slow
compared to fog. Try this:
fog {
  fog_type 2 // used ground type so it would fade out with elevation
  distance 75 // I shortened this to enhance the air effect some
  fog_alt 5
  fog_offset 0.0001
  color rgbt <0.5, 0.5, 0.8, 0.333> // decrease transmit value for denser
air
  rotate 90*x // needed so it is oriented correctly for your camera view
Only an example of course, nothing more. If you really must use media take a
look at the files posted at either povray.binaries.scene-files or
povray.text.scene-files. You'll need to search for something like "media
sky" or "rayleigh scattering". I found one just now by Nathan Kopp at the
binaries scene files group, subject Scattering media sky dated 11/1/2000.
bob h
