POV-Ray : Newsgroups : povray.general : Finish Map Server Time
30 Mar 2026 07:13:33 EDT (-0400)
  Finish Map (Message 1 to 7 of 7)
Subject: Finish Map
Date: 23 Mar 2002 01:52:39
Message: <3c9c2637$1@news.povray.org>
Is it possible to make a finish map? As in make certain parts of an object
have one finish and other parts have a different finish using an image?
Something like a material map but ONLY for the finishes? If I used a
material map there would be lots of overlap in the textures.
Corey
Subject: Re: Finish Map
Date: 23 Mar 2002 06:06:41
Message: <3c9c61c1@news.povray.org>
Hmm, why overlap? If you use a material map with reference to 3 textures
with different finishes but all contain the same pigment and normals, why
would this be a problem?
Btw, I've found a better way to make such maps: Put your image into a
function! From there you can evaluate the function and have it refer to all
the texture you want. The big advantages of this is that you can blend
between textures, and you don't have to use gif as input... I think soon
material maps will only stay in Povray for compatibility with old scenes.
Hugo
Date: 23 Mar 2002 14:31:54
Message: <3c9cd82a$1@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote in message
news:3c9c61c1@news.povray.org...
object
Because I'm using an insanely large bump map and image map already and
I dont' want them to be parced twice :)
all
Hmm I hadn't thought about functions at all. I check into it.
> Regards,
> Hugo
Corey
Date: 23 Mar 2002 14:48:42
Message: <3c9cdc1a$1@news.povray.org>
The maps won't be parsed twice if you declare them first and make references
to them in your textures. Like this:
#declare Image=pigment { image_map { tga "......." } }
#declare Bump=normal { bump_map { tga "...." } }
#declare Texture_1 = texture { pigment { Image } }
#declare Texture_2 = texture { pigment { Image } normal { Bump } }
--- the pigment is used twice but only loaded once.
Hugo
Date: 23 Mar 2002 20:16:51
Message: <3c9d2903$1@news.povray.org>
object
all
Ok I give! How do you do that. I know how to use a function as an image but
I havn't the slightest how to get an image to work as a function?!
Please Help :)
Corey
> Regards,
> Hugo
Date: 23 Mar 2002 22:56:55
Message: <3c9d4e87@news.povray.org>
Here you go.
d.
#declare P = function {  pigment {
  image_map {tga "whatever.tga"
    map_type 0
    interpolate 2
"Corey Woodworth" <cdw### [at] mpinetnet> wrote in message
news:3c9d2903$1@news.povray.org...
> object
image?
why
> all
scenes.
but
> Please Help :)
> Corey
> > Regards,
> > Hugo
Date: 24 Mar 2002 19:37:51
Message: <3c9e715f$1@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3c9d4e87@news.povray.org...
> Here you go.
> d.
>     map_type 0
>     interpolate 2
Oh wow I feel stupid :( Honest I checked the docs but I was looking for
something simlar to image functions etc.
Ok now I've got some more questions. :) I have a heightfield of the earth
and I want to make a sphere with this heightfield wrapped around it. How do
I do this with an isosurface? I've tried and tried. Do I need to use a
spherical warp instead? Here is what I have so far:
#version 3.5;
#declare EarthRadius  = 1;
#declare EarthHeight = function {  pigment {image_map { jpeg
"earthbump10k.jpg" map_type 1 interpolate 2 } } }
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -3.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 241/255, 237/255>  // light's color
  translate <-30, 30, -30>
isosurface {
  function { EarthHeight(x, y, z).hf }
  contained_by { sphere {<0, 0, 0>, EarthRadius} }
  accuracy 0.001
  max_gradient 4
  texture {pigment {color White } }
I'm sure once I get the hang of some of these more complicated things I'll
be askin' less questions :) I'm still very much a newbie!
Corey
