POV-Ray : Newsgroups : povray.general : shading model Server Time
11 Sep 2025 12:59:51 EDT (-0400)
  shading model (Message 1 to 10 of 11)
Subject: shading model
Date: 19 Feb 2002 00:45:27
Message: <3c71e677$1@news.povray.org>
Is there a way to modify the povray shading model without digging into the
source code (which I don't have for 3.5 anyway)?
I want to modify amount of lighting based on the angle between the camera
incidence ray and the normal vector of points in the mesh. My goal is to
create a scanning electron microscope look: bright edges (where the angle
between viewing ray and normal vector is larger) and a duller center (where
the angle is smaller).
I have tried using scattering media and backlighting the image, which works
well for simple objects (spheres), but breaks down when I try it on more
complex geometry. I have also checked out the documents for imformation
about trace(), which looked like it would work, but I never got it to work
for me.
Any ideas?
John
Subject: Re: shading model
Date: 19 Feb 2002 00:53:45
Message: <3c71e869$1@news.povray.org>
I have put an image of my scattering media attempt. It had the look I
wanted, but only because I did it on a sphere.
Date: 19 Feb 2002 01:44:09
Message: <chrishuff-4FAD0A.01435419022002@netplex.aussie.org>
In article <3c71e677$1@news.povray.org>,
Not really. You could possibly do it with functions: make separate red,
green, and blue functions, and use them as patterns for pigments in an
average pigment:
pigment {average
    pigment_map {
        [1 redFn color_map {[0 rgb 0][1 red 3]}]
        [1 greenFn color_map {[0 rgb 0][1 green 3]}]
        [1 blueFn color_map {[0 rgb 0][1 blue 3]}]
Use a finish with diffuse 0 and ambient 1, and do all your calculations
in those functions...very awkward for complex stuff though, especially
since you only have the intersection point available, you have to figure
out the other information yourself.
Put a light with negative intensity at the camera position, and give a
bright ambient to the texture. You might need to mess around with the
brilliance to fine-tune it.
#declare CamPos = < 0, 0,-5>;
    location CamPos
light_source {CamPos, color rgb -0.9}
sphere {< 0, 0, 0>, 1
        pigment {color rgb 1}
        finish {ambient 1 brilliance 2}
Date: 19 Feb 2002 01:59:30
Message: <3C71F81B.A88E331D@engineer.com>
http://www.pp.htv.fi/kkivisal/em.jpg
    slope {cam_lookat-cam_location,0,0.5}
    color_map{
      [0 rgb 0]
      [0.5 rgb 0.3]
      [1 rgb 1]
_____________
Kari Kivisalo
Date: 19 Feb 2002 08:21:44
Message: <3c725168$1@news.povray.org>
My HDD at work is full of about a Gb of SEM images. I've often wanted to
make such a texture.  Ever seen SEM's of solder paste?
Date: 19 Feb 2002 08:33:00
Message: <3C725402.EC4959F0@pacbell.net>
Yep. Have no idea how to model it though. Hmmm... maybe the old Suds
utility along with an isosurface...
Ken Tyler
Date: 19 Feb 2002 10:23:24
Message: <3c726dec$1@news.povray.org>
>  pigment {
>     color_map{
>       [0 rgb 0]
>       [0.5 rgb 0.3]
>       [1 rgb 1]
Slope was a great idea, thanks Kari. I tweaked it a bit and came up with a
look that I really like. I'll post an image in bin.images.
John
Date: 19 Feb 2002 11:03:19
Message: <3c727747$1@news.povray.org>
Use a negative brilliance.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 19 Feb 2002 11:50:23
Message: <3c72824f$1@news.povray.org>
This image has a few problems.
The neck under the teapot lid handle and the rim around the bottom of the
pot & cup are exactly wrong: these areas should be darker, as it would be
harder for a secondary electron emitted from these kinds of surfaces to make
it back to the detector.
The top rim of the teacup should be bright instead of dark.
An SEM has a detector sitting of to the side. This gives secondary electrons
emitted from surfaces facing the detector a greater chance of being detected
than those from surfaces facing the other way, almost as if there were a
light source over there.
Or so says my SEM mentor........
So perhaps a fix is either a combination of slope pigs OR a single
light_source off to the side.
Date: 19 Feb 2002 14:31:18
Message: <3c72a806@news.povray.org>
I tried this a way ago, too ...
What I did, was to create the object as an isosurface ...
one complete black object with threshold 0
and anotherone with threshold 0.01 and emitting media
what I neded to do was also to increase the accuracy of iso and
a lot of time ...
You may look want to look at
http://news.povray.org/3b9d44fb%40news.povray.org
The thing is, that the iso gives you more flexibility for design...
