POV-Ray : Newsgroups : povray.general : Could not save photon map - no photons! Server Time
24 Mar 2026 03:21:37 EDT (-0400)
  Could not save photon map - no photons! (Message 1 to 3 of 3)
Subject: Could not save photon map - no photons!
Date: 17 Feb 2002 13:14:22
Message: <3c6ff2fe@news.povray.org>
I am trying to figure out what I am doing wrong.  The photon map will not
save for some reason.
The hard drive has quite a bit of free space (9 gig free) and the directory
has full rights.  (Local directory on Windows XP)
The message window gives this error:
Scene contains 206 frame level objects; 0 infinite.
Here are my photon settings in the global section:
   photons {
      spacing 0.02
      gather 100, 100
      expand_thresholds 0.2, 30
      autostop 0
      save_file "WatchP3.pht"
     // load_file "WatchP3.pht"
Here is my light source:
light_source {< 30, 50, -70>
    color White * 1.25
    spotlight
    point_at <0, 0, 0>
    radius 5
    tightness 50
    falloff 6
    media_interaction
    photons {
      refraction on
      reflection on
      area_light
I have several objects using:
photons { target reflection on refraction off }
Any ideas what is wrong?
Thank you,
Patrick Dugan
Subject: Re: Could not save photon map - no photons!
Date: 17 Feb 2002 13:23:50
Message: <3c6ff536@news.povray.org>
Dou you use reflecting objects?
Do the reflected photons fall onto any other object?
Does the spotlight illuminate any target?
Does it work with a point light source?
Subject: Re: Could not save photon map - no photons! Solved. I think...
Date: 17 Feb 2002 13:44:27
Message: <3c6ffa0b@news.povray.org>
Yes
Yes
Yes, several.
I don't know yet.
I did discover that one object in the scene ( a rather large object) did not
have photons but should have.  Once I added the
photons to it, the file saved.  My guess is without that object's photons,
nothing else would "receive" them.
So your second question was probably the issue.
"Felix Wiemann" <Fel### [at] gmxnet> wrote in message
news:3c6ff536@news.povray.org...
