POV-Ray : Newsgroups : povray.general : Animating Color Maps Server Time
19 Jun 2026 10:01:11 EDT (-0400)
  Animating Color Maps (Message 1 to 5 of 5)
Subject: Animating Color Maps
Date: 11 Feb 2002 23:16:48
Message: <3c689730$1@news.povray.org>
Question for experts here.
Is there a way to animate a color map in POV Ray. In other words say I have
a terrain aerial map in color. I want to make an animation showing the color
of the trees going from green to brown and snow to appear. I can paint up
different color maps but how would I get them to change in POV Ray?
thanks,
Mitch
Subject: Re: Animating Color Maps
Date: 11 Feb 2002 23:25:39
Message: <3c689943@news.povray.org>
Mitchell Waite <mit### [at] dnaicom> wrote:
: Is there a way to animate a color map in POV Ray. In other words say I have
: a terrain aerial map in color. I want to make an animation showing the color
: of the trees going from green to brown and snow to appear. I can paint up
: different color maps but how would I get them to change in POV Ray?
  You can try something like this:
#declare Colors1 = array[3] { <0,0,0>, <1,0,0>, <1,1,0> }
#declare Colors2 = array[3] { <0,1,0>, <1,1,0>, <1,1,1> }
  color_map
  { #declare ColorsAmnt = dimension_size(Colors1, 1);
    #declare Ind = 0;
    #while(Ind < ColorsAmnt)
      #declare factor = Ind/(ColorsAmnt-1);
      [factor Colors1[Ind]*(1-factor)+Colors2[Ind]*factor]
      #declare Ind = Ind+1;
  Note that it works only if both color maps have the same number of
colors. Adding support for color maps with differing amount of colors makes
the problem a quite more complicated (but not impossible).
  Also if the colors are not distributes equally in the color_map, it would
need extra arrays for the index values.
Date: 11 Feb 2002 23:44:39
Message: <3c689db7@news.povray.org>
have
color
You can animate colour maps directly by adjusting their index and colour
values using the clock, e.g.:
color_map {
    [From (0, 0.1) To (1, 0.2) rgb <0.4, 0.2, 0>]
    [From (0, 1) To (1, 0.4) rgb From (0, <.2, .6, .3>) To (1, <.5, .3,
.1>)]
    [From (0, 1) To (1, 0.5) rgb <.95, .96, 1>]
This example uses the Automatic Clock Modifier macros
(http://www.geocities.com/ccolefax) to create a (very simplified) seasonal
change, the middle green section changing to brown and snow appearing from
above (when used as a gradient).  Any functions of the clock could be used
to create very complex, shifting colours.
For image-maps, or indeed colour maps, you can use the average pattern to
blend between two pigments/textures, e.g. (again using the macro file):
Texture_From (0, SummerTexture)
    To (0.25, AutumnTexture)
    To (0.5, WinterTexture)
    To (0.75, SpringTexture)
    To (1, SummerTexture)
Date: 11 Feb 2002 23:55:41
Message: <3c68a04d$1@news.povray.org>
Ah shucks I think I used the wrong term. I meant "image map" not color map.
I have this awesome targa bit map that I got which is an aerial shot of my
terrain taken from a plane. I can colorize it in a paint program. Then I
want to move successive versions of it on top of my wireframe height map in
POV. The color map idea wont' work for this approach at all. I need to know
if I can move bit maps in and out.
Mitch
"Chris Colefax" <chr### [at] tagpovrayorg> wrote in message
news:3c689db7@news.povray.org...
> have
> color
up
> color_map {
> .1>)]
Date: 12 Feb 2002 07:43:13
Message: <3c690de1@news.povray.org>
Then what you are looking for is something like this:
pigment
{ average pigment_map
  { [1-clock image_map { ... }]
    [clock image_map { ... }]
