POV-Ray : Newsgroups : povray.general : Spiral around a sphere. How? Server Time
23 Apr 2026 11:43:48 EDT (-0400)
  Spiral around a sphere. How? (Message 1 to 3 of 3)
Subject: Spiral around a sphere. How?
Date: 3 Feb 2002 18:43:48
Message: <3c5dcb34@news.povray.org>
I'm requesting some help for creating a small object.  I want to basically
wrap a rounded spiral around a sphere.
I have placed an example picture of what I'm trying to accomplish on the
povray.binaries.images.
The image I posted shows a roundish spiral snaking around a sphere.
How can I make something like that?  I'm no math whiz so I'm not sure what I
could use to make something like that.  Can you use an isosurface of some
sort or would it be a spline?
Basically I have no clue.  Any helpful input would be appreciated!
Patrick Dugan
Subject: Re: Spiral around a sphere. How?
Date: 4 Feb 2002 01:05:26
Message: <3c5e24a6$1@news.povray.org>
I
Well, I assume a sphere_sweep would be easiest. Let's create some basic
rules for it. The y value must go up steadily:
sphere_sweep {
 catmul_rom_spline // check spelling on this
 #declare numpoints = 20; // whatever
 numpoints
 #declare pointnum = 0;
 #while (pointnum < numpoints)
  , pointnum/(numpoints-1) // the value, from zero to one, that this point
on the spline should be
  , <???, pointnum/(numpoints-1)*2-1, ???>, radius
  #declare pointnum = pointnum + 1;
The pointnum/(numpoints-1)*2-1 is the y value, which will steadily increase
from -1 to 1. Now, as we go around the sphere, the X and Z values will be
sine and cosine times the radius of the cross section of the sphere at the
current y value. So...
#declare numrotations = 3;
sphere_sweep {
 numpoints
  , <cos(pointnum/(numpoints-1)*numrotations*2*pi),
     sin(pointnum/(numpoints-1)*numrotations*2*pi)>, radius
Now, that will wrap it around a cylinder. In order to wrap it around a
sphere, we have to multiply the x and z values by the radius of the cross
section of the sphere at the current y value. Since the equation of a circle
of radius 1 is y=sqrt(1-x^2)...
sphere_sweep {
 numpoints
  #declare cury = pointnum/(numpoints-1)*2-1
  , <cos(pointnum/(numpoints-1)*numrotations*2*pi) * sqrt(1-cury^2),
     cury,
     sin(pointnum/(numpoints-1)*numrotations*2*pi) * sqrt(1-cury^2)>, radius
That should do it, I think. All this code is untested. Think it all through
until you understand it; copying code won't get you anywhere the next time
you're faced with a problem to solve.
Oh, one more thing. If you want the radius to grow and then shrink, you'll
have to do that as some function of cury, such as radius = 1-cury^2.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 4 Feb 2002 09:09:15
Message: <3c5e960b$1@news.povray.org>
Thanks!!
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c5e24a6$1@news.povray.org...
what
> I
some
> sphere_sweep {
>  numpoints
>  #end
increase
> sphere_sweep {
>  numpoints
>  #end
circle
> sphere_sweep {
>  numpoints
>      cury,
radius
>  #end
through
> - Slime
