POV-Ray : Newsgroups : povray.general : isosurface Server Time
23 Apr 2026 13:28:04 EDT (-0400)
  isosurface (Message 1 to 7 of 7)
Subject: isosurface
Date: 30 Jan 2002 22:48:02
Message: <3c58be72$1@news.povray.org>
How do I get a pigment to work on an isosurface, the normal syntax will not
work, I mean c'mon. I gant even get a simple color on it, b/s using ambient,
which does no more justice to the curves and angles than does black.  I know
that this has probly been addressed b4, but I can't find it.
Thanx for your time.
""If you leave few things to chance, you will do few things poorly, but you
will do very few things."
Subject: Re: isosurface
Date: 31 Jan 2002 01:58:51
Message: <3c58eb2b@news.povray.org>
"TAlphaBravo" <TAl### [at] yahoocom> wrote in message
news:3c58be72$1@news.povray.org...
not
ambient,
know
It's easier to diagnose and solve a problem it there is code posted
The code below works (pov 3.5)
#include "functions.inc"
camera { location <0,4,-10> look_at <0,0,0>}
light_source {<-5,5,-20>  rgb 1}
light_source {<5,5,10> rgb 1}
isosurface {
 function {y-f_noise3d(x*3,0,z*3)}
 max_gradient 5
 contained_by {box {<-5,-1,-5>,<5,5,5>}}
  bozo
  scale 0.5
  color_map {
   [0.0 rgb <1,0,0>]
   [1.0 rgb <0,0,1>]
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Date: 31 Jan 2002 16:11:42
Message: <3c59b30e$1@news.povray.org>
Here is the problematic source code, I forgot it in my orginal message:
camera{location <10,10,-10> look_at <0,0,0>}
background{rgb 1}
light_source{<0,10,-10>, rgb 1
area_light 4,4,6,6
circular orient jitter}
isosurface {
    function {sqrt((x*y)^2+(y*z)^2+(z*x)^2-3)}
    max_gradient 36
    accuracy 0.01
    contained_by { sphere {<0,0,0>,6} }
  bozo
  scale 0.5
  color_map {
   [0.0 rgb <1,0,0>]
   [1.0 rgb <0,0,1>]
Date: 31 Jan 2002 16:42:27
Message: <3c59ba43@news.povray.org>
This is strange.
While it does not solve your problem, try this slightly varied code:
background{rgb 0}
light_source{<10,10,-10>, rgb 6
isosurface {
    max_gradient 36
    accuracy 0.00001
      rgb <1,0,0>
double_illuminate fixes is to some avail, but gives strange results anyway.
Perhaps you should report this to p.b-t? Higher max_gradient or lower
accuracy did not help at all.
Marc-Hendrik
Date: 31 Jan 2002 16:59:10
Message: <MPG.16c3dc7cb49f36659896d8@news.povray.org>
In article <3c59b30e$1@news.povray.org>, TAl### [at] yahoocom says...
I don't know why this doesn't work, but moving that -3 out of the sqrt
makes it work, without changing the shape much.
Lutz-Peter
Date: 31 Jan 2002 21:33:52
Message: <3c59fe90@news.povray.org>
"Lutz-Peter Hooge"  wrote in message .
Because the above function has imaginary values.
Because this does not have imaginary values.
R. Suzuki
Date: 31 Jan 2002 23:29:30
Message: <MPG.16c437f2ddd897129896d9@news.povray.org>
In article <3c59fe90@news.povray.org>, r-s### [at] aistgojp says...
Oops. Of course you are right.
Lutz-Peter
