POV-Ray : Newsgroups : povray.general : reset children ? (3.5Beta) Server Time
5 Mar 2026 06:42:29 EST (-0500)
  reset children ? (3.5Beta) (Message 1 to 10 of 12)
Subject: reset children ? (3.5Beta)
Date: 20 Jan 2002 10:01:33
Message: <3c4adbcd$1@news.povray.org>
I remember, there was something like this in Megapov ... Never tried it,
though
Now I've come along a situation, where I'd need it ... is this in 3.5 ?
PovDoc doesn't reveal anything 'bout it ...
I have some textures, used inside a texture_map ...
It would be a lot of work, to divide it into pigment_map, normal_map... and
finish_map isn't possible
Reverse transformation of these inner textures is hard to compute ...
So easiest would be a reset_children thingie ..
suggestions ?
My code looks something like this :
#declare LPos=f1(clock);
#declare SphPos=f2(clock);
#declare Tex1=texture {
    pigment { ...
    normal {...
    finish {...
    scale ...
    translate ...
#declare Tex2=texture {
    pigment { ...
    normal {...
    finish {...
    scale ...
    translate ...
#declare Tex=texture {
    gradient vnormalize(SphPos-LPos)
    scale 2
    translate vnormalize(LPos-SphPos)
    texture_map {
        [0.0 Tex1]
        [1.0 Tex2]
as you can see, Tex1 and Tex2 will be transformed together with Tex, but they
should
stay, where they are...
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzernet>
Subject: Re: reset children ? (3.5Beta)
Date: 20 Jan 2002 10:14:23
Message: <chrishuff-365C2E.10151720012002@netplex.aussie.org>
The reset_children feature was not added to 3.5, but the same effect is
possible. Since you are using plain transformations, you can do this:
#declare TexTrans = transform {
    scale 2
#declare Tex = texture {
    transform {TexTrans}
    texture_map {
        [0.0 Tex1 transform {TexTrans inverse}]
        [1.0 Tex2 transform {TexTrans inverse}]
More complex textures using warps are a different matter, you would have
to do something like:
    function {
        pattern {
            scale 2
            turbulence 0.5
    texture_map {
        [0.0 Tex1]
        [1.0 Tex2]
Date: 20 Jan 2002 10:56:32
Message: <3c4ae8af@news.povray.org>
I think that the reset_children was found obsolete because the same
functionality can be achieved with pigment_pattern or functions.
Date: 20 Jan 2002 11:06:13
Message: <3c4aeaf5$1@news.povray.org>
Ah ... OK ...
> but the same effect is possible. Since you are using
>     scale 2
>     texture_map {
Thanks so far ... You gave me the idea, but your solution doesn't work ...
Can this be a bug ?
I can't write
   transform {TexTrans}   // Parser Error
nor
   transform {TexTrans inverse}   // Parser Error
but only
   transform TexTrans
I can write:
#declare TexTrans=transform { scale 2 translate P1-P2 }
and
#declare TexTransInv=transform { scale 2 translate P1-P2 inverse }
Can this be a bug ?
I'll put a minimal Example, with error to p.b-t.b
Date: 20 Jan 2002 11:07:34
Message: <3c4aeb46$1@news.povray.org>
Can it in this case ? ...
As you can see, I want to do it with complete textures, without having to
split them up ...
also I use different finishes, and I don't think there's an finish_map ...
Date: 20 Jan 2002 11:15:11
Message: <chrishuff-B34563.11160620012002@netplex.aussie.org>
In article <3c4aeaf5$1@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
wrote:
> Can this be a bug ?
It's a bug, but I thought it was fixed in the most recent version.
Date: 20 Jan 2002 11:38:58
Message: <3c4af2a2@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: also I use different finishes, and I don't think there's an finish_map ...
  But there's a texture_map.
Date: 20 Jan 2002 11:41:43
Message: <3c4af347@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3c4af2a2@news.povray.org...
... which I'm using ...
.. but it doesn't reset the children...
Date: 20 Jan 2002 11:48:35
Message: <chrishuff-2FA576.11493020012002@netplex.aussie.org>
In article <3c4aeb46$1@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
> split them up ...
The function pattern technique will let you do this. It is basically
warping the pattern itself instead of the texture.
Date: 20 Jan 2002 11:51:20
Message: <3c4af588$1@news.povray.org>
Yes .. I've seen this ... I replied to Warp ...
