POV-Ray : Newsgroups : povray.general : A glass box that doesn't distort? Server Time
5 Mar 2026 08:17:38 EST (-0500)
  A glass box that doesn't distort? (Message 1 to 9 of 9)
Subject: A glass box that doesn't distort?
Date: 10 Jan 2002 21:56:35
Message: <3c3e5463$1@news.povray.org>
Group:
I am trying to make a glass box to enclose my terrain height map object.
I use two glass cubes and make a CSG object and use the difference.
The result is that the glass really distorts the mountain object inside it
and it lowers the overall impact.
Is there a way to make a glass cover that does not distort its contents, so
you just seen shiny glass and not all the internal distortion.
Thanks in advance for shedding any light on this for me :)
Mitch
//  Persistence of Vision Raytracer V3.1
//  World definition file.
//  Contains 3 lights, 12 materials and 11 primitives.
//  This file was generated for POV-Ray V3.1 by
//  Moray V3.3a For Windows Copyright (c) 1993-2001 Lutz + Kretzschmar
//  Date : 01/10/2002    (10.01.2002)
/* // Scene Comment
This scene was created with Moray V3.3a For Windows.
*/ // End Scene Comment
global_settings {
  adc_bailout 0.003922
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 1.9
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 10
  number_of_waves 10
background { color <0.000,0.000,0.000> }
camera {  //  Camera Camera01
  location  <   1028.694,    -992.172,     449.995>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.35179,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray) aspect
ratio
  angle         34.59700    // Vertical      25.948
  look_at   <     54.180,     -49.953,       4.341>
//    Other cameras are commented out.
camera {  //  Camera SpotCam001
  location  <    729.067,    -192.330,     -61.058> // Attached to
Spotlight001
handed-system
  right     <    1.37972,         0.0,         0.0> // Right Vector is
ratio
  angle         53.27389    // Vertical      39.955
  look_at   <    490.186,    -193.317,     -62.880> // Following
Spotlight001
// *******  L I G H T S *******
light_source {   // Spotlight Spotlight001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  spotlight
    point_at  <0.0, 0.0, -2.000>
    falloff    20.615  // outer radius (in deg)
    radius     10.356  // inner radius
    tightness  1.387
  scale <90.494003, -255.016724, 238.889862>
  rotate <-251.658951, -268.61087, -251.427094>
  translate  <729.066792, -192.329781, -61.057676>
light_source {   // Arealight Arealight001
  <0.0, 0.0, 0.0>
  area_light <2.000, 0.000, 0.000>, <0.000, 2.000, 0.000>, 3, 3
  adaptive 1
  jitter
  scale 167.608353
  translate  <5.826545, -57.846504, 171.319905>
light_source {   // Light001
  <0.0, 0.0, 0.0>
  scale 6.955595
  translate  <215.112179, -214.486228, 99.536085>
// ********  MATERIALS  *******
#include "mttamtable2.inc"
// ********  REFERENCED OBJECTS  *******
// ********  OBJECTS  *******
difference { // cover_master
  box { // cover_outside
    <-1, -1, -1>, <1, 1, 1>
    material {
      Glass_1
    scale <-249.562454, -323.243469, -46.517822>
    rotate -180.0*z
    translate  <-12.285776, 39.706477, -1.646869>
  box { // cover_inside
    material {
      Glass_1
    scale <-243.759888, -315.727753, -45.436237>
    rotate -180.0*z
    translate  <-13.114714, 39.706477, -5.79156>
  material {
    Glass_1
text {   // MtTamalpais
  ttf    "C:\WINNT\Fonts\Ariblk.ttf",
  "Mt Tamalpais",
  1.0,  // Depth
  <0.0,   0.0, 0.0> // Offset
  material {
    PDB_Tex_CG
  scale <28.110615, 28.314674, 7.156415>
  rotate <90.0, -0.4496, 89.985313>
  translate  <273.703176, -301.308515, -77.868465>
difference { // CSG001
  box { // base
    material {
      pop_wood
    scale <-292.466003, -375.171814, -15.374308>
    rotate -180.0*z
    translate  <-15.685786, 38.13311, -65.559882>
  box { // inside_base
    material {
      pop_wood
    scale <-242.609192, -312.308899, -9.420569>
    rotate -180.0*z
    translate  <-13.304292, 38.13311, -52.461662>
  material {
    Maple
  translate  -4.058934*z
box { // table
  material {
    DMFWood4
  scale <582.428162, 887.263733, 5.445363>
  translate  <-10.922797, 38.13311, -90.99404>
box { // sky
  material {
    Light_Clouds
  scale 1981.290649
object {   // HgtFld001
  height_field {
    tga "C:\_My Documents\solid terrain modeling\mtTam Height.tga"
    water_level 0.001
    smooth
  rotate    <-90, 0, 0> // Turn onto XY plane. Now points along -Z
  scale     <  2, 2,-2> // Scale to Cube size. Now points along +Z
  translate < -1,-1,-1> // Center around origin
  material {
    mtTam_Color_Map
    scale <2.001502, 2.001009, 1.0>
    translate <-1.001253, -1.000302, -0.987980>
  scale <233.633926, 300.57309, 33.389656>
  translate  <-11.717504, 38.220091, -28.279904>
Subject: Re: A glass box that doesn't distort?
Date: 10 Jan 2002 22:27:48
Message: <3C3E5D0D.E18B8844@applesnake.net>
is it a simple IOR problem or a rendering artifact problem?  if
IOR, uh, lower it (raise it) closer to 1.
-peter
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 10 Jan 2002 23:35:49
Message: <3c3e6ba5@news.povray.org>
That did it, thanks.
"Dearmad" <dea### [at] applesnakenet> wrote in message
news:3C3E5D0D.E18B8844@applesnake.net...
> -peter
Date: 11 Jan 2002 22:37:05
Message: <3c3faf61$1@news.povray.org>
Mitchell Waite wrote:
> Group:
> so you just seen shiny glass and not all the internal distortion.
I am having trouple rendering your scene, I get this error:
Parsing...camera {  //  Camera Camera01
handed <----ERROR
glassbox.pov:35: error: No matching } in camera, undeclared identifier
'handed' found instead.
I'm using POVray v.3.1g.Linux.gcc   Anyone know how to correct his problem?
 Thanks
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
9:28pm up 3 days, 48 min, 0 users, load average: 1.36, 1.42, 1.31
Date: 11 Jan 2002 22:39:55
Message: <3C3FB032.832F518C@pacbell.net>
David F wrote:
>   sky       <0,0,1> // Use right handed
Ken Tyler
Date: 11 Jan 2002 22:46:06
Message: <3c3fb17e$1@news.povray.org>
DOH!  word wrap
David
ICQ#: 118347772
Date: 11 Jan 2002 22:52:25
Message: <3c3fb2f9@news.povray.org>
Do you need my materials file, be happy to send it?
"David F" <smu### [at] ameritechnet> wrote in message
news:3c3faf61$1@news.povray.org...
> > Group:
it
> handed <----ERROR
problem?
>  Thanks
> David
> ICQ#: 118347772
Date: 11 Jan 2002 22:54:49
Message: <3c3fb389$1@news.povray.org>
sure, that'd be great.
David
ICQ#: 118347772
Date: 12 Jan 2002 00:04:13
Message: <3c3fc3cd@news.povray.org>
If you want the actual height map and color overlay let me know and I will
send it to you directly.
news:3c3fb389$1@news.povray.org...
> David
> ICQ#: 118347772
Download 'mttamtable.inc.txt' (8 KB) Download 'mtTamTable.INI.txt' (2 KB) Download 'mtTamTable.mdl.dat' (9 KB) Download 'mttamtable.pov.txt' (5 KB)
