POV-Ray : Newsgroups : povray.general : Help with IDENTIFIER and MACRO needed. Server Time
25 May 2026 05:49:18 EDT (-0400)
  Help with IDENTIFIER and MACRO needed. (Message 1 to 5 of 5)
Subject: Help with IDENTIFIER and MACRO needed.
Date: 15 Nov 2001 18:38:16
Message: <3bf451e8@news.povray.org>
I've come across a problem that I don't know how to resolve. If I set up a
spline
eg.
#declare MySpline=
spline {
linear_spline
0, <0,0,0>
1, <1,1,1>
 why is it that the following doesn't work, and is there a workaround?
#declare SplinePoint=MySpline(clock); //Gives error
Also (this may be the same problem in a different guise), why does the
following not work, and is there a workaround for this too?
#macro MyMacro (Point1, Point2, Num)
#local New=Point2-Point1+Num;
MyMacro (MySpline(clock),<3,3,3>,6) //Gives error
Thanks in advance,
Andy Cocker
Subject: Re: Help with IDENTIFIER and MACRO needed.
Date: 16 Nov 2001 00:37:47
Message: <3bf4a62b@news.povray.org>
Andrew Cocker wrote in message <3bf451e8@news.povray.org>...
It doesn't work because POV-Ray sees the "MySpline", decides that you are
declaring "SplinePoint" as a spline, and gets confused when it finds "("
rather than ";" or "{".  The workaround is:
#declare SplinePoint=<0,0,0>+MySpline(clock);
This tells POV-Ray that you are declaring SplinePoint as a vector.
>#end
I think it's the same problem.  I could be more certain if you had posted
the error message.
Mark
Date: 16 Nov 2001 07:00:05
Message: <3bf4ffc5@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3bf4a62b@news.povray.org...
> the error message.
Thanks Mark. Will see if that fixes the second problem. If not, will post
error message.
All the best,
Andy Cocker
Date: 16 Nov 2001 08:04:41
Message: <slrn9va3na.f46.ron.parker@fwi.com>
Can't you also #declare SplinePoint=(MySpline(clock)); ?
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 16 Nov 2001 09:29:52
Message: <3bf522df@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Can't you also #declare SplinePoint=(MySpline(clock)); ?
  And make it look more like Lisp? H*** no! ;)
