POV-Ray : Newsgroups : povray.general : Wrapping a HF around a Cylinder Server Time
27 Nov 2025 22:10:07 EST (-0500)
  Wrapping a HF around a Cylinder (Message 1 to 4 of 4)
Subject: Wrapping a HF around a Cylinder
Date: 2 Nov 2001 11:32:07
Message: <3be2ca87@news.povray.org>
I seem to recall someone describing a way to wrap a heightfield around a
cylinder.  Does anyone else remember this, or was I just dreaming?
Cris Williams
Subject: Re: Wrapping a HF around a Cylinder
Date: 2 Nov 2001 12:10:08
Message: <3BE2D369.102908E2@gmx.de>
There's a HF_Cylinder macro in Povray 3.5 shapes.inc that generates a
mesh.  Apart from that you can also use an isosurface with an image
map/image_pattern function.
Date: 2 Nov 2001 14:24:54
Message: <3be2f306$1@news.povray.org>
> heightfield around a cylinder.  Does anyone else
Technically you can't wrap a height_field object around a cylinder, but you
can create a mesh object that is just like it.
With POV-Ray 3.5 is an include file "shapes.inc" which has a macro to do
just that. (POV-Ray 3.5 is currently in the beta stage. You can download a
time-limited beta from www.povray.org for windows or mac.)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 3 Nov 2001 07:53:44
Message: <DRAHLFAr+647Ew1C@econym.demon.co.uk>
You may not be able to wrap a height_field round a cylinder, but you can
wrap an image_map pigment around a cylinder (using map_type 2). In v3.5
any pigment can be used as an isosurface function, so we can combine the
cylindrical image_map function with a cylindrical isosurface.
Note: I've applied a scaling of y/pi to the HF function in this example,
so that a square heightfield image looks correctly proportioned when
stretched round a cylinder. Alternatively create a heightfield image
that is pi times wider than it is high.
camera { location  <0, 2, -6> look_at <0, 0, 0>}
light_source {<-100,200,-100> colour rgb 1}
light_source {<100,-200,-100> colour rgb 1}
#declare  Cyl = function {x^2 + z^2 -1}
#declare  HF  = function {pigment {image_pattern {jpeg "foo.jpg"
map_type 2 interpolate 2}}}
#declare F=function{Cyl(x,0,z) - HF(x,y/pi,z).grey} // See Note
isosurface {
  function { F(x,y,z) }
        max_gradient 20
        contained_by{box{-1.5,1.5}}
        pigment {rgb 1}
Mike Williams
Gentleman of Leisure
