POV-Ray : Newsgroups : povray.general : Passing macro as parameter Server Time
16 Jul 2026 21:29:10 EDT (-0400)
  Passing macro as parameter (Message 1 to 7 of 7)
Subject: Passing macro as parameter
Date: 28 Oct 2001 08:49:15
Message: <3bdc0cdb$1@news.povray.org>
Is there any way that I can pass the name of a macro as a paramter to
another macro?  For example, I'm defining one macro, F(X, Z) as a function
and I would like to pass this as one of the parameters to another macro.
But when I put Macro1(F), it tells me it's expecting a '('.
Thanks,
Kev
Subject: Re: Passing macro as parameter
Date: 28 Oct 2001 08:56:34
Message: <3bdc0e92@news.povray.org>
First you define your two macros, then you can use one as a parameter for
the other one:
example (not tested)
#macro SQUARE (A)
A*A
#macro INCR (B)
B+1
#declare c=SQUARE ( INCR (2) ); // it should give you (2+1)^2=9
Date: 28 Oct 2001 09:09:52
Message: <3bdc11b0$1@news.povray.org>
That's sort of different from what I'm tring to do.  I'm trying to make a
macro that can make a graph of surfaces defined by Y = F(X, Z), and I want
to pass F(X, Z) as a parameter to the macro.  But not just one value of F, I
want to be able to pass the function F, so I can call it several times
inside of the macro.  If this isn't clear, then I can post my code so you
can see what I have so far and what I'm trying to get.  Right now I am
declaring F outisde of the graph macro, but this is no good because I might
want to use two different F's in one scene.
Thanks,
Kev
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3bdc0e92@news.povray.org...
> the other one:
> #macro SQUARE (A)
> A*A
> #end
> #macro INCR (B)
> B+1
> #end
Date: 28 Oct 2001 09:29:42
Message: <3bdc1656@news.povray.org>
Hmm, let's see if I've understood you:
you have a macro called F (X,Z) defined as follows (I guess):
F (X,Z)
*expression with X and Z*
Then you have another macro you want to pass F to it as a parameter (but you
don't want it to be F(X0,Y0) where X0 and Y0 are predefined values).
Then I guess you want to evaluate F inside the second macro.
Are you using POV 3.5? If that's the case why don't you simply define the
function inside the second macro?
i.e:
#macro Macro1()
#declare F=function (X,Z) { *expression with X and Z*}
and then you can evalute F inside the macro.
Jonathan.
"Kilgore Trout" <lou### [at] hotmailcom> ha scritto nel messaggio
news:3bdc11b0$1@news.povray.org...
I
might
> Thanks,
> Kev
for
> > the other one:
> > #macro SQUARE (A)
> > A*A
> > #end
> > #macro INCR (B)
> > B+1
> > #end
Date: 28 Oct 2001 09:46:34
Message: <3bdc1a4a$1@news.povray.org>
I am using 3.1 still.  I will try what you suggested with 3.5.
Thanks!
Kevin
news:3bdc1656@news.povray.org...
> F (X,Z)
> #end
you
> i.e:
> #macro Macro1()
> Jonathan.
a
want
F,
> I
you
> might
> > Thanks,
> > Kev
> for
> > > the other one:
> > > #macro SQUARE (A)
> > > A*A
> > > #end
> > > #macro INCR (B)
> > > B+1
> > > #end
Date: 28 Oct 2001 14:00:37
Message: <3bdc55d5$1@news.povray.org>
You could also have them pass the name of the macro as a string, and then
use that evalString function in strings.inc (that's not exactly what it's
called, but it's something like that).
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Kilgore Trout" <lou### [at] hotmailcom> wrote in message
news:3bdc1a4a$1@news.povray.org...
> Thanks!
> Kevin
> > F (X,Z)
> > #end
> you
the
> > i.e:
> > #macro Macro1()
> > Jonathan.
make
> a
> want
of
> F,
> > I
> you
> > might
> > > Thanks,
> > > Kev
parameter
> > for
> > > > the other one:
> > > > #macro SQUARE (A)
> > > > A*A
> > > > #end
> > > > #macro INCR (B)
> > > > B+1
> > > > #end
Date: 28 Oct 2001 19:32:42
Message: <3BDCA387.B7B95B1@hotmail.com>
Kilgore,
if you've downloded POV-Ray v3.5.beta by now,
(as JRG suggested) then maybe my example code
below will be useful for you. It shows how to
pass user declared functions to macros as
parameters.
You may also wan't to have a look at isosurfaces.
They are very useful for graphing in 3D.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
// By Tor Olav Kristensen
// Email: tor### [at] hotmailcom
// http://www.crosswinds.net/~tok
#version 3.5;
#include "golds.inc"
#macro FunctionPlot(Fn, p1, p2, nn, Radius)
  #local dX = (p2 - p1).x/nn;
  #local dZ = (p2 - p1).z/nn;
  #local X = p1.x;
  #while (X < p2.x)
    #local Z = p1.z;
    #while (Z < p2.z)
      #local Y = Fn(X, 0, Z);
      sphere { <X, Y, Z>, Radius }
      #local Z = Z + dZ;
    #end // while
    #local X = X + dX;
  #end // while
#end // macro FunctionPlot
#declare SombreroFn =
function(x, y, z) { 10*sin(sqrt(x^2 + z^2))/(sqrt(x^2 + z^2) + 1) }
#declare pA = -35*<1, 0, 1>;
#declare pB =  35*<1, 0, 1>;
union {
  FunctionPlot(function { SombreroFn(x, y, z) }, pA, pB, 200, 0.4)
  texture { T_Gold_2B }
/* // This code will produce a somewhat disturbed "sombrero"
#declare BozoFn =
function { pattern { bozo scale 4 } }
#declare MixedFn =
function(x, y, z) { SombreroFn(x, 0, z) - 2*BozoFn(x, 0, z) }
union {
  FunctionPlot(function { MixedFn(x, 0, z) }, pA, pB, 200, 0.4)
sky_sphere { pigment { color Blue/2 } }
light_source { < 5,  4, -1>*10 color White shadowless }
  location <2, 5, -7>*2
  look_at <0, -4, 0>
