POV-Ray : Newsgroups : povray.general : Blob suggestion Server Time
27 Nov 2025 22:10:25 EST (-0500)
  Blob suggestion (Message 1 to 10 of 10)
Subject: Blob suggestion
Date: 28 Oct 2001 01:05:04
Message: <3bdb9200$1@news.povray.org>
What I wanna see is a blob object that can model any of the primatives into
a blob, I know of times when this would be a Godsend!]
Subject: Re: Blob suggestion
Date: 28 Oct 2001 02:10:20
Message: <AxyHjBAZ8627EwGg@econym.demon.co.uk>
Most of the POV primitives can be represented by isosurfaces. It's
possible to blob isosurfaces together (see below) in both POV 3.5 and
MegaPOV. The following classes of primitives that can't (easily) be
represented by isosurfaces:-
1. Some Finite Patch Primitives: Bicubic patch, mesh, mesh2 and
smooth_triangle. The other finite patch primitives (polygon, disc,
triangle) can be easily represented as flat isosurfaces that have a
small thickness. It could well be argued that the concept of blobbing
finite patches is not meaningful.
2. Julia_Fractal
3. Text
4. Sphere_Sweep
Any other primitives can be easily represented by isosurfaces and then
blobbed.
From <http://www.econym.demon.co.uk/isotut/combine.htm>
  Blob-like combinations
  #include "functions.inc"
  #declare  S = function {f_sphere(x,y,z,0.5)}
  #declare  T = function {f_torus(x,y,z,1,0.2)}
  isosurface {
    function { S(x-0.7,y,z) * T(x,y,z) - 0.05}
         max_gradient 2
         accuracy 0.001
         contained_by{sphere{0,R}}
         pigment {rgb .9}
  [The MegaPOV syntax for the sphere and torus built in functions is ]
  [#declare S = function {"sphere" <.5>}                             ]
  [#declare T = function {"torus" <1,0.2>}                           ]
  Multiplying surfaces then adding a small constant produces an effect
  that's similar to using blobs. However, this technique can be used to
  blob together any kind of isosurface, not just spheres and cylinders.
Also, in MegaPOV, it's possible to perform isosurface blobbing of any
object by creating the isosurfaces from proximity patterns of the
objects. Proximity patterns are not available in POV3.5. MegaPOV
proximity patterns are rather slow.
Mike Williams
Gentleman of Leisure
Date: 28 Oct 2001 09:47:41
Message: <3bdc1a8d@news.povray.org>
TAlphaBravo <TAl### [at] yahoocom> wrote:
: primatives
  I wonder why this form if the word "primitive" is so popular.
Date: 28 Oct 2001 10:07:23
Message: <3bdc1f2b$1@news.povray.org>
Maybe it's just a typo... just like *if* instead of *of*  ;-)
Jonathan.
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3bdc1a8d@news.povray.org...
> : primatives
Date: 28 Oct 2001 11:57:53
Message: <3BDC3910.5E38DD84@free.fr>
And maybe not. On Slackware forums, I often see "kernal" for
"kernel" and other similar errors that I don't have in mind
right now. I think it's some kind of "slang pronunciation"
that gets written down by users that don't care that much
about the correctness of their writings.
Adrien Beau   adr### [at] freefr   http://adrien.beau.free.fr/
Date: 28 Oct 2001 12:08:37
Message: <3bdc3b95@news.povray.org>
And what about that ugly *fibinocci* I hear sometimes...
Jonathan.
"Adrien Beau" <adr### [at] freefr> ha scritto nel messaggio
news:3BDC3910.5E38DD84@free.fr...
Date: 28 Oct 2001 12:49:41
Message: <3BDC44E9.5090904@videotron.ca>
Bad spelling due to bad pronounciation is understandable, especially
when it is with names of people that are from a different ethnicity than
the person mentioning it.
What bugs me is people - mostly native english-speakers - who routinely
confuse "its" and "it's" and "then" and "than".
followups set.
> Jonathan.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 29 Oct 2001 04:28:08
Message: <3bdd2128@news.povray.org>
Only problem is isosurfaces are a lot slower and can get artefacts more often...
- Nekar
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:Axy### [at] econymdemoncouk...
> 2. Julia_Fractal
> 3. Text
> 4. Sphere_Sweep
> blobbed.
>   isosurface {
>          max_gradient 2
>          accuracy 0.001
>          pigment {rgb .9}
> Mike Williams
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 29 Oct 2001 13:53:07
Message: <$hDI3BAaDa37EwpE@econym.demon.co.uk>
But blobs that did this might well be even slower than isosurfaces, and
it's fairly easy to get rid of the artefacts in the vast majority of
cases.
Mike Williams
Date: 30 Oct 2001 07:10:18
Message: <3bde98aa@news.povray.org>
news:$hDI### [at] econymdemoncouk...
often...
> cases.
I'm beginning to think isosurfaces might just be easier as well, seeing the
actual diameter stays the same in isosurfaces - less of a guessing game..?
- Nekar
