POV-Ray : Newsgroups : povray.general : bug with transparant object behind transparant difference? Server Time
16 Jul 2026 23:00:30 EDT (-0400)
  bug with transparant object behind transparant difference? (Message 1 to 3 of 3)
Subject: bug with transparant object behind transparant difference?
Date: 25 Oct 2001 16:17:20
Message: <3bd87350@news.povray.org>
Forgive the weird subject of this posting, but that's as close as I get to
the origin of the problem.
I use a transparant difference to create a spherical shell. Visible through
this shell is a part of a transparant cyclinder. For some reason the rays
that pass through both objects end up with the wrong color.
The following code is a minimum example that exhibits this problem. It was
rendered with version 3.1g.watcom.win32 on Windows 95 SE.
Any ideas anybody? Am I right in the assumption that this is a bug, or am I
overlooking something obvious?
Berend Meijer
// A nearly transparant vertical cyclinder ...
cylinder
  <0,-1,0>, <0,0,0>, 0.5
  pigment
    color <1,1,1>
    filter 0.8     // <-- This seems to be (part of) the problem
// ... with on top a nearly transparant spherical shell ...
difference
  sphere
    <0,0.5,0>, 0.5
  sphere
    <0,0.5,0>, 0.49
  pigment
    color <1,1,1>
    filter 0.9
// ... against a white background
plane
  <0,0,-1>, -2
  pigment
    color <1,1,1>
light_source
  <3,3,0>
  color <1,1,1>
camera
  location <0,1,-3>
  look_at <0,0,0>
Subject: Re: bug with transparant object behind transparant difference?
Date: 25 Oct 2001 16:24:51
Message: <3bd87513@news.povray.org>
Have you already tried increasing the max_trace_level value in the
global_settings block (from its default value of 5)?
Date: 25 Oct 2001 16:37:49
Message: <3bd8781d@news.povray.org>
It was the 'overlooking something obvious'. Increasing max_trace_level does
the trick.
Thanks.
news:3bd87513@news.povray.org...
