POV-Ray : Newsgroups : povray.general : Night crowd? Server Time
25 May 2026 07:48:20 EDT (-0400)
  Night crowd? (Message 1 to 7 of 7)
Subject: Night crowd?
Date: 22 Oct 2001 18:50:06
Message: <3bd4a29e$1@news.povray.org>
I'm working on a new scene- tell y'all about it when it's a bit further
along- and I was wondering if there's a way to simulate a crowd without
costing too much extra rendering time. The scene is at night, and only the
front of the crowd is going to be seen in any level of detail. I'm planning
to make the "people" ambient 0 diffuse 0, black, so form isn't really a
concern- I just want to give the impression of a cheering crowd. Can 3.5 do
this without sending rendering speed down the loo?
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: Night crowd?
Date: 22 Oct 2001 19:14:01
Message: <3bd4a839$1@news.povray.org>
Hmm... put reflective planes, perpendicular to the ground, behind the crowd.
Then put a no_image reflective plane in *front* of the crowd. Camera rays
will bounce back and forth between the two planes until they hit a member of
the crowd.
Of course, that could cause problems, you'd need to set max_trace_level
really high, and you might need the planes to be only partially reflective
so that adc_bailout will save you fast enough. But if those don't matter
that much, give it a shot.
(Also, render times may still be just as slow. Only parsing times will speed
up, I suppose.)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Mahalis" <don### [at] fakeycom> wrote in message
news:3bd4a29e$1@news.povray.org...
planning
do
> //Mahalis
Date: 22 Oct 2001 19:42:20
Message: <3bd4aedc$1@news.povray.org>
I don't care that much about parse times, so I'm thinking of just making a
few simplistic people in various poses and then copying those with a #while
loop. Thanks though...
//Mahalis
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bd4a839$1@news.povray.org...
crowd.
of
> the crowd.
speed
> up, I suppose.)
> - Slime
the
> planning
> do
> > //Mahalis
Date: 23 Oct 2001 00:25:37
Message: <3bd4f141$1@news.povray.org>
If they are going to be entirely black, why not make an image to use as a
height field of people? kind of like cardboard cutouts.
ross.
news:3bd4aedc$1@news.povray.org...
#while
> //Mahalis
> crowd.
rays
member
> of
> > the crowd.
reflective
> speed
> > up, I suppose.)
> > - Slime
further
without
> the
> > planning
a
3.5
> > do
> > > //Mahalis
1][0.1
Date: 23 Oct 2001 07:10:47
Message: <3bd55037@news.povray.org>
That's a possibility, but I tried the "cone people" approach last night and
got pretty much the effect I wanted...
Another question: Would Nathan Kopp's NKFlare work for making camera
flashes?
//Mahalis
"Ross Litscher" <lit### [at] osuedu> wrote in message
news:3bd4f141$1@news.povray.org...
> ross.
a
> #while
> > //Mahalis
> > crowd.
> rays
> member
> > of
> > > the crowd.
max_trace_level
> reflective
matter
> > speed
> > > up, I suppose.)
> > > - Slime
> further
> without
only
> > the
> > > planning
really
> a
> 3.5
> > > do
> > > > //Mahalis
> 1][0.1
Date: 23 Oct 2001 15:57:29
Message: <3BD5CD60.2F7197A4@hotmail.com>
> further along- and I was wondering if there's a way to simulate a
> crowd without costing too much extra rendering time. The scene is at
> night, and only the front of the crowd is going to be seen in any
> level of detail. I'm planning to make the "people" ambient 0 diffuse
> 0, black, so form isn't really a concern- I just want to give the
> impression of a cheering crowd. Can 3.5 do this without sending
3.1 can easily.  Get a bunch of gifs or PNGs of people.  Load them into a paint
program.  Paint
their background with color #0 from the
palette.  Ensure that everything else is another color.
Now apply each of these images to a polygon, using them as material
maps.
polygon { 5, 0,x,x+y,y,0
  material_map { png "dude01.png"
  texture { pigment { rgbt 1 } }
  texture { pigment { rgb 0 } }
This will make color zero a fully transmitting texture and all the
other colors a dead black.
If your starting picture already features a crowd, this will be
easier; then you need fewer polygons.
Hope this helps,
John
ICQ: 46085459
Date: 23 Oct 2001 16:28:45
Message: <3bd5d2fd@news.povray.org>
Hey, that sounds better than my heightfield idea. kinda similar though. i
imagine faster too.
paint program.  Paint
> maps.
> Hope this helps,
> John
> ICQ: 46085459
