POV-Ray : Newsgroups : povray.general : #macro question Server Time
30 Dec 2025 18:13:22 EST (-0500)
  #macro question (Message 1 to 9 of 9)
Subject: #macro question
Date: 11 Oct 2001 00:32:33
Message: <3bc520e1@news.povray.org>
two things, is it possible to return a 2 dimensional array from macro, and
then assign it to another matrix? povray won't let me do this and I'm not
sure if there is a way to do it. there is nothing on it in the docs.
eg.
currentPositions = evaluateInitialPositions( lengthSegs, widthSegs, clothL,
clothW, randomness )
currentPositions and the value returned from evaluateInitialPositions both
have the same dimensions
second question, is there anyway to set up a refernece parameter in a macro?
for example in c++ you add an ampersand(&) infront of the variable in the
function definition
thanks in advance
Kevin
Subject: Re: #macro question
Date: 11 Oct 2001 02:21:12
Message: <pBtRtOA0mTx7EwoG@econym.demon.co.uk>
>eg.
I think your problem lies in the fact that you expect a macro to
*return* something (like a function in C++). In POV code, a macro
doesn't return anything it just *is* something.
The following code works.
#macro Fred(A,B)
   array[2][2]{{0,A},{2,B}}
#declare Jim = Fred(1,3)
You don't need to pre-declare Jim as a 2d array. It even works if you
had previously declared Jim to be a completely different data type.
Another way of thinking about what POV macros return would be to
consider that Fred(1,3) doesn't return an array, it returns the *text*
"array[2][2]{{0,1}{2,3}}", which then gets parsed as if you had typed
"#declare Jim = array[2][2]{{0,1}{2,3}}". This is very different from
what happens in C++ function.
>function definition
I reckon that such a concept is meaningless in the context of POV
macros.
Mike Williams
Gentleman of Leisure
Date: 11 Oct 2001 05:39:42
Message: <3bc568dd@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: Another way of thinking about what POV macros return would be to
: consider that Fred(1,3) doesn't return an array, it returns the *text*
  This is not the whole story. #local declarations are not seen outside the
macro, although the value of a locally declared identifier can be passed
outside the macro.
  This example shows how this #local behaviour is seen in practice:
#macro MyMacro()
  #local MyVar = 5;
#declare MyVar = 2;
MyMacro()
#debug str(MyVar,0,0) // 'MyVar' is still 2 here!
Date: 11 Oct 2001 05:40:58
Message: <3bc56929@news.povray.org>
Kevin Loney <klo### [at] pt2mcom> wrote:
: second question, is there anyway to set up a refernece parameter in a macro?
  For what purpose?
  (Macros are not functions, so parameters are not passed by value anyways...)
Date: 11 Oct 2001 09:10:26
Message: <slrn9sb6i3.chi.ron.parker@fwi.com>
>outside the macro.
With care.  POV 3.5 has at least one bug with this, and I suspect it existed
in POV 3.1 as well.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 11 Oct 2001 09:20:13
Message: <slrn9sb74e.chi.ron.parker@fwi.com>
>  For what purpose?
Well, they are and they aren't.  Parameters are references unless they can't
be a reference.  This:
#macro Foo(A)
  #declare A=5;
#declare B=10;
#declare C=20;
Foo(B);
Foo(0+C);
leads to two different results.  B gets set to 5, but C gets left alone,
because "B" can be passed as a reference but the expression "0+C" can't.
Date: 11 Oct 2001 11:18:06
Message: <3bc5b82e@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Foo(0+C);
: leads to two different results.  B gets set to 5, but C gets left alone,
: because "B" can be passed as a reference but the expression "0+C" can't.
  As a programmer I would interpret that in the way that a temporary
indentifier is created in order to hold the result of "0+C", and a reference
to this temporary identifier is passed to the macro. After the macro call
ends, this temporary identifier is destroyed.
  So macros always take "references", but you should know when temporary
identifiers are created in order to avoid mistakes.
Date: 11 Oct 2001 11:23:30
Message: <slrn9sbebk.cj4.ron.parker@fwi.com>
>: Foo(0+C);
Except that's not actually how it's implemented.  A local is created in
both cases, but in one case it's a local of type "reference to parameter"
and in the other case it's a local of type "floating point value."
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 11 Oct 2001 11:49:31
Message: <3bc5bf8b@news.povray.org>
:>  As a programmer I would interpret that in the way that a temporary
: Except that's not actually how it's implemented.  A local is created in
: both cases, but in one case it's a local of type "reference to parameter"
: and in the other case it's a local of type "floating point value."
  That's why I said "I would interpret"... ;)
