POV-Ray : Newsgroups : povray.general : Rendering patterns different in 3.1 and 3.5? Server Time
14 Jan 2026 08:29:18 EST (-0500)
  Rendering patterns different in 3.1 and 3.5? (Message 1 to 8 of 8)
Subject: Rendering patterns different in 3.1 and 3.5?
Date: 15 Sep 2001 00:34:46
Message: <3ba2da66@news.povray.org>
I noticed that rendering patterns in POV-Ray 3.1 and 3.5 give different
results.  Rendering in POV-Ray 3.5 with the following texture (as given by
Ricky[Kitty]5 in povray.binaries.images under 'more glass balls...') yields
a very soft pattern to objects this material is applied to.  But when
rendered in POV-Ray 3.1, the pattern appears much more defined.  Why the
change?  Is there any convention to use so that a scene with materials
intended to be rendered in POV-Ray 3.1 can be rendered in POV-Ray 3.5 with
the same look, or is it just a matter of manually tweaking?
I've posted images in povray.binaries.images comparing the same pattern
rendered in 3.1 and 3.5.
#declare Material1 =
   material  // Material1
      texture
         pigment
            color rgb <1.0, 1.0, 1.0>
         normal
            bozo , 0.5
            turbulence 0.5
            ramp_wave
         finish
            ambient 0.0
            diffuse 0.6115
-Paragon
Subject: Re: Rendering patterns different in 3.1 and 3.5?
Date: 15 Sep 2001 02:17:57
Message: <3ba2f295@news.povray.org>
After reading more on documentation, I've learned that MegaPOV attempted to
fix the way POV-Ray rendered surface normals, and this is the reason for the
inconsistencies when trying to render the patterns in POV-Ray 3.1 and 3.5
(I've also read about noise_generator, but this was not as helpful).  So
knowing this, I guess I'll be content with using #version 3.1 to get the
results I want.  Though I'm still curious on how I can get better results
with those patterns without using #version 3.1...
-Paragon
Date: 15 Sep 2001 04:00:17
Message: <3ba30a90@news.povray.org>
Paragon <use### [at] hostcom> wrote:
: (I've also read about noise_generator, but this was not as helpful).
  How so? To me the documentation seems quite clear in this issue.
Date: 15 Sep 2001 17:07:00
Message: <3ba3c2f4$1@news.povray.org>
Yes, but the textures still render differently.  I use #noise_generator 1
but still yields different results.  I posted again in
povray.binaries.images comparing POV-Ray 3.1 and 3.5 using #noise_generator
1.
-Paragon
news:3ba30a90@news.povray.org...
Date: 15 Sep 2001 18:10:46
Message: <3ba3d1e5@news.povray.org>
: I use #noise_generator 1
  Where did you get that # from?
Date: 15 Sep 2001 18:44:34
Message: <3ba3d9d2@news.povray.org>
I got that from the POV-Ray 3.5 documentation.  In 2.6.1, it states
"You can also choose noise_generator 1, which behaves like the noise in
POV-Ray 3.1 and earlier,"
-Paragon
Date: 15 Sep 2001 18:47:08
Message: <3BA3DB70.B0ECC465@pacbell.net>
He was referring to the '#' symbol that you showed in your example.
Ken Tyler
Date: 16 Sep 2001 05:20:53
Message: <3ba46ef4@news.povray.org>
:>   Where did you get that # from?
: I got that from the POV-Ray 3.5 documentation.  In 2.6.1, it states
  It doesn't say anything about a # character before the command.
