![](/i/fill.gif) |
Can someone explain to me why I get a "thick-walled tube" with the
following code?
#declare actuald=2;//d*0.125;
#declare scopey=
union{
difference{
cylinder {<0,0,-0>,<0,0,3>,actuald+.000000100}
cylinder {<0,0,-.1>,<0,0,3.1>,actuald}
pigment{Brown} finish {ambient 0.8}
object {scopey rotate <0,0,0>}
location <0, 0, -15> //was z of 15
angle 22
look_at <0,0,60>
light_source { <80, 1620, 80> color White }
light_source { <-4000, -400, -4000> color White*.6 }
![](/i/fill.gif) |
![](/i/fill.gif) |
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3b89ae44@news.povray.org...
> following code?
> #declare scopey=
> union{
> difference{
> camera {
> location <0, 0, -15> file://was z of 15
> angle 22
> look_at <0,0,60>
Try the following:
#declare scopey=
union{
difference{
pigment{
gradient z
color_map {
[0 color rgb 0]
[1 color rgb 1]
scale <1,1,3>
finish {ambient 1}
angle 22
look_at <0,0,0>
Basically, the tube itself is very thin walled, but the far end of the tube
is much smaller (on the screen) than the near end. Because of this, you get
the illusion of a thick wall. Really, you're just looking inside the tube.
The gradient pattern above should highlight this.
...Chambers
![](/i/fill.gif) |
