POV-Ray : Newsgroups : povray.general : Another one for the math wizards out there Server Time
25 May 2026 15:53:53 EDT (-0400)
  Another one for the math wizards out there (Message 1 to 5 of 5)
Subject: Another one for the math wizards out there
Date: 24 Aug 2001 17:24:28
Message: <3b86c60c$1@news.povray.org>
I have an arbitrarily shaped surface that consists of millions of triangles.
I know the coordinates of each triangular vertex as well as the normal at
each vertex.
I also have a line defined by two points and I know the coordinates of each
point.
How do I calculate the point on the line where the surface and the line
intersect?
Thanks for the help.
Jim
Subject: Re: Another one for the math wizards out there
Date: 24 Aug 2001 17:34:53
Message: <slrn9odi40.rc2.ron.parker@fwi.com>
>each vertex.
>point.
>intersect?
trace(). :)
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 24 Aug 2001 17:54:09
Message: <3B86CC97.EF7198B4@spiritone.com>
> each vertex.
> point.
> intersect?
> Jim
Ron has the best answer.
The long way would mean testing each triangle to see if it crosses the line.
To test is a line intersects a triangle, you have to find the intersection of
the line and the plane defined by that triangle, then determine if that point
is in the triangle.
Trace is the fastest solution
Josh English
eng### [at] spiritonecom
Date: 25 Aug 2001 00:52:22
Message: <3b872f06$1@news.povray.org>
Thanks Ron and Josh.
Is there some information in the documentation on how to use "trace"?  I
looked through the help files but could find nothing that explained how to
do a "trace".
Thanks.
Jim
Date: 25 Aug 2001 02:07:24
Message: <3b87409c@news.povray.org>
"Jim Kress" <dea### [at] kressworkscom> wrote in message
news:3b872f06$1@news.povray.org...
> do a "trace".
MegaPOV needed until POV-Ray v3.5 is available.  The help files are
downloadable from Nathan Kopp's site.  http://nathan.kopp.com/patched.htm
then the download link there.
You basically declare vectors which will encompass the object area; to be
traced for a surface contact point, as well as the normal direction of its
surface at that point.
Bob H.
