POV-Ray : Newsgroups : povray.general : Rotations... Server Time
31 Dec 2025 01:56:44 EST (-0500)
  Rotations... (Message 1 to 6 of 6)
Subject: Rotations...
Date: 6 Aug 2001 20:41:19
Message: <3b6f392f$1@news.povray.org>
OK, my brain must be really fried, because I can't
think up the answer to this...
I have a vector which is perpendicular to a plane.
From this vector, how should I rotate an object so
that it lies in the plane?  The vector is represented
by a point along that axis.
...Chambers
Subject: Re: Rotations...
Date: 6 Aug 2001 22:45:00
Message: <3B6F2C11.A54195C8@peak.edu.ee>
Not sure what you need, but you might want to try John VanSickle's
Reorient macro:
#macro Reorient(Axis1,Axis2)
        #local vX1=vnormalize(Axis1);
        #local vX2=vnormalize(Axis2);
        #local vY=vnormalize(vcross(vX1,vX2));
        #local vZ1=vnormalize(vcross(vX1,vY));
        #local vZ2=vnormalize(vcross(vX2,vY));
        matrix < vX1.x, vY.x,vZ1.x, vX1.y,vY.y,vZ1.y, vX1.z,vY.z, vZ1.z,
0,0,0 >
        matrix < vX2.x,vX2.y,vX2.z,  vY.x,vY.y, vY.z, vZ2.x,vZ2.y,vZ2.z,
0,0,0 >
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 6 Aug 2001 23:58:06
Message: <3b6f674e@news.povray.org>
"Margus Ramst" <mar### [at] peakeduee> wrote in message
news:3B6F2C11.A54195C8@peak.edu.ee...
> Reorient macro:
> 0,0,0 >
> 0,0,0 >
> #end
Hmm... neat, but I can't seem to make it work...
Ok, I have here an object:
sphere {
 0,1
 scale <5,1,5>
I also have three points on a plane (lets call them
p1,p2,p3).  I'd like to have this flattened sphere
oriented on the plane...  Maybe I'm just braindead
tonight, but the reorient macro didn't do it for
me...
Thanks in advance...
...Chambers
Date: 7 Aug 2001 02:11:36
Message: <3B6F8712.3DA22325@atosorigin.com>
> ...Chambers
Looks like you have the same question that I had : rotation
around an arbitrary vector.
I do not remember if I asked in p.g or p.a-u, but
you should find the answer in the mid-june/mid-july 2001 posts.
There is two solutions for you: either a transform matrix,
or a patch with a keyword.
Date: 7 Aug 2001 05:30:48
Message: <3B6F8B2E.F2056CFD@peak.edu.ee>
> sphere {
>  0,1
>  scale <5,1,5>
> me...
If the plane is described by 3 points, you first need the normal vector
of the plane:
Normal=vnormalize(vcross(p2-p1,p3-p1))
and the distance along that normal:
Distance=vdot(p1,Normal)
Now to align your flattened sphere with the plane, using the Reorient
macro:
sphere{
  0,1
  scale <5,1,5>
  Reorient(y,Normal)
  translate Normal*Distance
This is untested, but as far as I can see, should work.
Margus Ramst
Date: 7 Aug 2001 11:32:54
Message: <3B700B1D.3DF5ED5F@hotmail.com>
> me...
Hello Ben
See my suggestion code below.
I hope it does what you want.
Best regards
from Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2001 by Tor Olav Kristensen
// mailto:tor### [at] hotmailcom
// http://www.crosswinds.net/~tok
#version 3.1;
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
// Define a macro that does the same as
// John VanSickle's Reorient macro.
// (But with a slightly different method.)
#macro ReorientMatrix(vAxis1, vAxis2)
  #local v1 = vnormalize(vAxis1);
  #local v2 = vnormalize(vAxis2);
  #local vU = vcross(v1, v2);
  #local Dot = vdot(v1, v2);
  #local v0 = vnormalize(vU);
  #local vW = (1 - Dot)*v0;
  matrix <
    v0.x*vW.x + Dot,  v0.x*vW.y + vU.z, v0.x*vW.z - vU.y,
    v0.y*vW.x - vU.z, v0.y*vW.y + Dot,  v0.y*vW.z + vU.x,
    v0.z*vW.x + vU.y, v0.z*vW.y - vU.x, v0.z*vW.z + Dot,
    0,                0,                0
#end // macro ReorientMatrix
// Define 3 points that lies on the plane
#declare p1 = <1, 2, 3>;
#declare p2 = <2, -1, -1>;
#declare p3 = <-1, 0, 1>;
// Show the 3 points
sphere { p1, 0.2 pigment { color Red } }
sphere { p2, 0.2 pigment { color Green } }
sphere { p3, 0.2 pigment { color Blue } }
// Calculate a normal vector for the plane
#declare vNormal = vnormalize(vcross(p2 - p1, p3 - p1));
// Calculate the common transformations
#declare TiltAndTranslate =
transform {
  ReorientMatrix(y, vNormal)
  translate (p1 + p2 + p3)/3
// See note 1 below for other translate statements
// that can replace the line above.
// Then define your other stuff
#declare YourPlane =
plane {
  y, 0
  pigment { color Grey }
// See note 2 below
#declare YourSphere =
sphere {
  <0, 0, 0>, 1
  scale <5, 1, 5>
//  scale 1/4 // Uncomment if you want to see all the 3 points
  pigment { color Yellow }
// And transform it into place
object {
  YourPlane
  transform TiltAndTranslate
object {
  YourSphere
light_source { <-2, 20, -1>*5 color White }
  location <1, 3, 2>*3
  look_at <0, -1, 0>
Note 1:
Here are some alternate translate
statements that also will work:
translate vdot(p1, vNormal)*vNormal
translate vdot(p2, vNormal)*vNormal
translate vdot(p3, vNormal)*vNormal
translate p1
translate p2
translate p3
translate (p1 + p2)/2
translate (p1 + p3)/2
translate (p2 + p3)/2
...and so on...
Note 2:
It's sometimes easier to work with
a disk instead of a plane. E.g.:
disc {
  <0, 0, 0>, y, 10
