POV-Ray : Newsgroups : povray.general : Holes in SuperEllipsoids Server Time
25 May 2026 20:10:24 EDT (-0400)
  Holes in SuperEllipsoids (Message 1 to 9 of 9)
Subject: Holes in SuperEllipsoids
Date: 8 Jul 2001 10:19:08
Message: <3b486bdc@news.povray.org>
I am tryting to create a difference between two Superquadric Ellipsoid
Objects.  Whenever I do this the object has some odd cutouts that appear at
certain angles.  I will post the image example in the binaries/images area.
Anything I can do to get the same object shape without the cutouts?  Here is
my questionable code...
#version unofficial MegaPov 0.7;
global_settings {
   assumed_gamma 2.2
   max_trace_level 25
light_source {< -500, 500, -500> color White * 1.0}
camera { location <0,0,-3> look_at  <0,0,0>}
difference {
   superellipsoid {<0.25, 0.25> scale <1.00,1.00,1.00>}
   superellipsoid {<0.25, 0.25> scale <0.98,0.98,2.01>}  // deeper on z axis
to create cutout...
   scale <1,0.25,0.15>
   texture {pigment {Green} finish {ambient 0.4}}
   rotate <-90,0,90>
   rotate y * 45
sphere {<0,0,0> , 1300.0 texture {pigment { Gray90 }} hollow}
Subject: Re: Holes in SuperEllipsoids
Date: 8 Jul 2001 21:17:51
Message: <3B490638.D342FF02@worldnet.att.net>
Well, that looks like the normal on some of the triangles got flipped somewhere
inside POV.  You can get the same shape with a CSG, "rounded box".  Here's
some code, the first part is a RoundBox macro and the second your example
rewritten to use it.
// ----- RoundBox -----
// LocA and LocB are box corners, Rad1 is the rounding radius
#macro RoundBox(LocA, LocB, Rad1)
merge {
  #local B1 = <LocA.x+Rad1,LocA.y+Rad1,LocA.z+Rad1>;
  #local B2 = <LocA.x+Rad1,LocA.y+Rad1,LocB.z-Rad1>;
  #local B3 = <LocB.x-Rad1,LocA.y+Rad1,LocB.z-Rad1>;
  #local B4 = <LocB.x-Rad1,LocA.y+Rad1,LocA.z+Rad1>;
  #local T1 = <LocA.x+Rad1,LocB.y-Rad1,LocA.z+Rad1>;
  #local T2 = <LocA.x+Rad1,LocB.y-Rad1,LocB.z-Rad1>;
  #local T3 = <LocB.x-Rad1,LocB.y-Rad1,LocB.z-Rad1>;
  #local T4 = <LocB.x-Rad1,LocB.y-Rad1,LocA.z+Rad1>;
  sphere{B1, Rad1}
  sphere{B2, Rad1}
  sphere{B3, Rad1}
  sphere{B4, Rad1}
  sphere{T1, Rad1}
  sphere{T2, Rad1}
  sphere{T3, Rad1}
  sphere{T4, Rad1}
  cylinder{B1, B2, Rad1}
  cylinder{B2, B3, Rad1}
  cylinder{B3, B4, Rad1}
  cylinder{B4, B1, Rad1}
  cylinder{T1, T2, Rad1}
  cylinder{T2, T3, Rad1}
  cylinder{T3, T4, Rad1}
  cylinder{T4, T1, Rad1}
  cylinder{T1, B1, Rad1}
  cylinder{T2, B2, Rad1}
  cylinder{T3, B3, Rad1}
  cylinder{T4, B4, Rad1}
  box{<B1.x,B1.y,LocA.z>,<T3.x,T3.y,LocB.z>}
  box{<LocA.x,B1.y,B1.z>,<LocB.x,T3.y,T3.z>}
  box{<B1.x,LocA.y,B1.z>,<T3.x,LocB.y,T3.z>}
  bounded_by{box{LocA,LocB}}
// ----- scene -----
global_settings {
   assumed_gamma 2.2
   max_trace_level 25
difference {
   object {RoundBox(<-1,-1,-1>,<1,1,1>,.5) scale <1.00,1.00,1.00>}
   object {RoundBox(<-1,-1,-1>,<1,1,1>,.5) scale <0.98,0.98,2.01>}
   scale <1,0.25,0.15>
   bounded_by{box{<-1,-.25,-.15>,<1,.25,.15>}}
   rotate <-90,0,90>
   rotate y * 45
light_source{<-9,9,-9>rgb x+y+z}text{ttf"timrom.ttf"    // timothyea
"Tim Attwood".1,0 pigment{rgb x+y}translate<-2.7,-.3,5>}// @worldnet.att.net
sky_sphere {pigment{gradient y color_map{[.45 rgb<.2,.3,.2>][0.5 rgb x+y+z]
[0.55 rgb x+y][0.6 rgb x+.5*y][.7 rgb 0]}scale 2 translate -1}}
Date: 9 Jul 2001 00:44:26
Message: <3b4936aa@news.povray.org>
Thank you!  That works very nicely.  I still can't figure out what why the
SEO messes up.
"Tim Attwood" <tim### [at] worldnetattnet> wrote in message
news:3B490638.D342FF02@worldnet.att.net...
at
area.
Here is
somewhere
> merge {
>   sphere{B1, Rad1}
>   sphere{B2, Rad1}
>   sphere{B3, Rad1}
>   sphere{B4, Rad1}
>   sphere{T1, Rad1}
>   sphere{T2, Rad1}
>   sphere{T3, Rad1}
>   sphere{T4, Rad1}
> #end
> global_settings {
>    assumed_gamma 2.2
>    max_trace_level 25
> difference {
>    scale <1,0.25,0.15>
>    rotate <-90,0,90>
>    rotate y * 45
@worldnet.att.net
x+y+z]
Date: 9 Jul 2001 01:41:42
Message: <3b494416$1@news.povray.org>
Patrick Dugan wrote in message <3b4936aa@news.povray.org>...
>SEO messes up.
I haven't tested your scene code, but it sounds like a known bug with
superellipsoids.  To the best of my knowlege, it has been fixed in the
latest version of MegaPOV, and will be fixed in the next official version of
POV-Ray.
Mark
Date: 9 Jul 2001 02:48:09
Message: <3b4953a9@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3b494416$1@news.povray.org...
the
> >SEO messes up.
of
> POV-Ray.
Not v0.7 and don't count on it for v3.5.
Bob H.
Date: 10 Jul 2001 14:52:05
Message: <chrishuff-DBE04A.13503310072001@povray.org>
In article <3B490638.D342FF02@worldnet.att.net>,
> somewhere inside POV.
The scene he posted didn't use any triangles, just a CSG difference with
two superellipsoids. This is probably an error in the solving method,
maybe some intersections are not being found.
> You can get the same shape with a CSG, "rounded box".  Here's some
BTW, the shape of a "rounded box" is not exactly the same as a
superellipsoid...the superellipsoid doesn't have any truely flat areas.
A CSG shape might actually be faster than a similar superellipsoid...it
will use more memory, of course. Another solution would be to use a
difference of two isosurface superellipsoids...isosurfaces use a
completely different solving method which might render without
artifacts, and can sometimes be faster...though harder to use.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 11 Jul 2001 04:09:05
Message: <3B4C0999.4B6E9E0C@worldnet.att.net>
I meant that... (some internal POV tesselation error).
Actually RoundBox is very close on the flatish areas, and differs more
where it actually curves: the superellipsoid follows a parabolic. Here's
a scene to show the difference.
 location  <0, 0, -3.0>
 look_at   <0, 0,  0.0>
 orthographic
union {
  object {RoundBox(<-1,-1,-1>,<1,1,1>,.5) pigment {Blue}}
  superellipsoid{<.25,.25> pigment{Red} translate <0,0,2>}
  translate <1,-1,0>
  scale <4,4,.25>
  translate <-1,1,0>
Maybe a superellipsoid could be more closely approximated by scaling some
of the RoundBox components then rotating them.
Date: 11 Jul 2001 08:50:23
Message: <3B4C4B87.37BBE2EF@pacbell.net>
Except in a couple of cases (like HF's and bicubic patches) POV-Ray
does not do internal tesselation. All of POV-Ray's primitives are
mathematical constructs and are not internally tesselated. Which is
also true of the superellipsoid object.
Date: 11 Jul 2001 18:57:46
Message: <3B4CD9E1.5CC09A87@worldnet.att.net>
Well, it is a triangle shaped hole. *shrug*
