POV-Ray : Newsgroups : povray.general : loading radiosity data Server Time
14 Jan 2026 13:06:24 EST (-0500)
  loading radiosity data (Message 1 to 2 of 2)
Subject: loading radiosity data
Date: 6 Jul 2001 18:22:14
Message: <3b463a16@news.povray.org>
I wonder if anyone can help.
I'm trying to get megapov to load radiosity data for use in a scene.
Whenever I put load_file into the radiosity block megapov then attempts
to pretrace the scene again as if it had ignored the instruction. Even
when pretrace_start and pretrace_end have been commented out, it is
still trying to calculate some values.
What lines should I remove or leave in the radiosity block so that
megapov will use the data I have already saved?
Many thanks,
Steve
Subject: Re: loading radiosity data
Date: 11 Jul 2001 20:50:56
Message: <3b4cf470$1@news.povray.org>
Steve,
Try setting both pretrace_start and pretrace_end to big numbers (maybe set
them to the same number).  Also, make sure you have the file name correct
and that the file is located in the same folder as the POV file (POV might
not complain if it can't find the file).
-Nathan
"sacrofts" <sac### [at] tinyonlinecouk> wrote...
Whenever I put load_file into the radiosity block megapov then attempts to
pretrace the scene again as if it had ignored the instruction. Even when
pretrace_start and pretrace_end have been commented out, it is still trying
What lines should I remove or leave in the radiosity block so that megapov
Many thanks,
Steve
