POV-Ray : Newsgroups : povray.general : 2 line sig :) Server Time
28 Nov 2025 08:55:57 EST (-0500)
  2 line sig :) (Message 1 to 10 of 12)
Subject: 2 line sig :)
Date: 9 May 2001 14:05:57
Message: <3af98705@news.povray.org>
#default{finish{reflection 1}}text{ttf"ariblk.ttf""Tek".2,0 scale 3 translate-<3
,1,1>}sphere{1.6*z,1}sky_sphere{pigment{bozo colour_map{[0rgb 0][1rgb 1]}}}//tek
Subject: Re: 2 line sig :)
Date: 9 May 2001 18:25:48
Message: <3af9c3ec@news.povray.org>
translate-<3
1]}}}//tek
That's cheating!
cu!
Date: 9 May 2001 20:01:25
Message: <slrn9fjmin.jvl.ron.parker@fwi.com>
On Thu, 10 May 2001 00:25:38 +0200, Zeger Knaepen wrote:
>That's cheating!
But if that's cheating, then two of mine were cheats.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 10 May 2001 02:20:53
Message: <3afa3345@news.povray.org>
I  can't seem to render the sigs that use fonts even though the fonts are
installed into windows. Should I copy the fonts into the includes directory?
Nekar X
#local N=<-4,8,20>;#local K=<4,-8,20>;#local R=seed(0);union{#while((K-N).x>0)
#local X=N;#local N=N+<rand(R),rand(R),1>/30;#local N=(vlength(N-K)<vlength(X-K
)?N:2*X-N);sphere{<N.y,-N.x,N.z>,.2}sphere{N,.2}sphere{<-N.x-8,N.y,N.z>,.1//-NX
pigment{rgb N}}sphere{<N.x+8,-N.y,N.z>,.1 pigment{rgb N}}#end pigment{rgb 9}}
Date: 10 May 2001 02:53:23
Message: <3afa3ae3@news.povray.org>
Nekar Xenos <j-p### [at] citywalkcoza> wrote in message
news:3afa3345@news.povray.org...
directory?
Nope, add the following line to povray.ini
Library_Path=C:\Windows\Fonts
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Date: 10 May 2001 03:27:25
Message: <3afa42dd@news.povray.org>
Thanks Gail.
Nekar
Date: 10 May 2001 04:20:48
Message: <3AFA4F60.5F3712C1@stress.uio.no>
> translate-<3
> 1]}}}//tek
> That's cheating!
So's this.
#include "x" //Simen Kvaal.
Date: 10 May 2001 05:52:04
Message: <3afa64c4@news.povray.org>
Tek <tek### [at] evilsuperbraincom> wrote:
: #default{finish{reflection 1}}text{ttf"ariblk.ttf""Tek".2,0 scale 3 translate-<3
: ,1,1>}sphere{1.6*z,1}sky_sphere{pigment{bozo colour_map{[0rgb 0][1rgb 1]}}}//tek
  I think that the main idea of these type of signatures is obfuscation. That
is, you don't see what kind of image the code will generate and when you try
it you get a surprise. Also an important thing about an obfuscated signature
is that you can't easily see _how_ does it do what it does.
  (Even when you can somehow see from the signature that it creates certain
types of objects and where are the, for examples, coordinates coded, you still
don't easily see what kind of image it will exactly produce and how the
coordinates are decoded.)
  Another negative thing is that your signature requires a system-specific
font file only available to certain users, which contradicts the portable
nature of povray.
  Without these things it's very easy to make even a one-liner. But that
doesn't have any challenge at all.
Date: 10 May 2001 13:51:03
Message: <3afad507@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3afa64c4@news.povray.org...
Sorry, I'm a professional programmer and my tendency in any code (even pov) is
to make it as clear and simple to understand as is possible :) Just 'cause
something's hard to read doesn't make it clever.
Though, I appreciate the suprise element. I'll have to come up with another one.
Date: 10 May 2001 14:09:41
Message: <3afad965$1@news.povray.org>
Perhaps something more like this (BTW, it's meant to look like my initials). And
just 1.5 lines!
plane{z,2 pigment{bozo colour_map{[.6rgb 1][.6rgb 0]}translate <.2,.4,.2>}finish
{ambient 1}} // Tekno Frannansa. www.evilsuperbrain.com.
