POV-Ray : Newsgroups : povray.general : italicized text Server Time
14 Jan 2026 18:32:23 EST (-0500)
  italicized text (Message 1 to 7 of 7)
Subject: italicized text
Date: 30 Mar 2001 18:01:20
Message: <3ac51040@news.povray.org>
Is there a way to tell POVRay to italicize or otherwise modify (such as
bold, underline, strikethrough, etc.) text objects? I'm aware that some
fonts have separate italicized, bold and italicized-bold font files, but the
one I need to use doesn't.
Thanks,
Bill
Subject: Re: italicized text
Date: 30 Mar 2001 18:51:54
Message: <3ac51c1a$1@news.povray.org>
You'll have to use a font with the capability you need, as there aren't text
properties to set from within the text statement.
Bob H.
"Bill Brehm" <bbr### [at] netzeronet> wrote in message
news:3ac51040@news.povray.org...
> Hi,
the
> Thanks,
> Bill
Date: 30 Mar 2001 21:57:40
Message: <slrn9caht8.14g.ron.parker@fwi.com>
On Fri, 30 Mar 2001 16:01:45 -0700, Bill Brehm wrote:
>Hi,
You can skew the text with a matrix, I suppose, but it won't really be
italic, technically.  For underline or strikethrough, you'll have to
create and position boxes appropriately.  For bold, the only thing I
can offer is to create two copies of the string and offset them a bit
horizontally so the vertical strokes get thicker, but of course that
only works for fonts that already have fine horizontal strokes.  Arial,
for example, will not look like Arial Bold if you thicken it horizontally.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 31 Mar 2001 01:24:04
Message: <3AC57805.FFEAB4AD@gmx.de>
For bold you could also use a proximity pattern isosurface, probably
extremely slow.  Another possibility would be a heightfield where an
erosion filter was applied before.
Date: 31 Mar 2001 18:45:15
Message: <3ac66c0b@news.povray.org>
What about using a shear transform on the text object?
Bill Brehm <bbr### [at] netzeronet> wrote in message
> Hi,
the
> Thanks,
> Bill
Date: 1 Apr 2001 01:31:49
Message: <3ac6cb55@news.povray.org>
You could try to find a similar font that has
italics, bold and normal or get hold of a font
designer/editor program and create an italic
font from the one you have.
=Bob=
"Bill Brehm" <bbr### [at] netzeronet> wrote in message news:3ac51040@news.povray.org...
: Hi,
: Is there a way to tell POVRay to italicize or otherwise modify (such as
: bold, underline, strikethrough, etc.) text objects? I'm aware that some
: fonts have separate italicized, bold and italicized-bold font files, but the
: one I need to use doesn't.
: Thanks,
: Bill
Date: 1 Apr 2001 01:37:14
Message: <3AC6CD45.953F7203@pacbell.net>
Bill Brehm wrote:
> Hi,
When all else fails use your favorite paint program to create 2d text
then use that as a height field object.
Another possible option would be Elefont - http://www.armanisoft.ch/
Ken Tyler
