![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm trying to get a texture that looks something like a splash against a
verticle surface. Ie, throwing something messy against the surface and
having it run down. In this case, it's the effuvium from a pipe verticle
next to the wall. So the stain needs to go out and down.
Has anyone done anything like this, and does anyone have any tips? I've
tried a variety of methods, but nothing looks very good.
Thoughts?
Geoff
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thoughts?
> Geoff
You could try Chris Huff's particle system patch, AFAIK it also allows to
make pigments from the simulated particles.
Of course the 'running down' could be problematic, the visibility pattern
I wrote (Megapov MCP) could be used for that, but right now it's probably
not flexible enough.
Another attempt would be to code something with blobs and maybe use blob
pattern / object pattern.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thoughts?
Weird. I almost posted the same message earlier this week!!!
Francois Labreque | And a four year old carelessly banging on a toy
flabreque | piano is not only 'music', it's probably the last
@ | moment of 'artistic purity' they'll ever enjoy
videotron.ca | before outside influences start corrupting their
| expression. - Chris R.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Geoff Wedig wrote in message <3ab27cfe@news.povray.org>...
>having it run down.
Try using a texture_map to get the shape right.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, I wanted to avoid particles and such. I've come up with something
procedural that isn't bad using Megapov's functions, and could probably be
made better with some work.
Since someone else asked, I'm posting it here. IF anyone has any
suggestions for making it better (the point at the top bothers me) I'd love
to hear them.
Geoff
#version unofficial Megapov 0.7;
camera
location <0,20,0>
look_at 0
light_source
<0,1000,0>
1
// A streaking pattern. Standard bozo 10 times longer on the x.
#declare funct =
function
pigment
bozo
color_map
[0 rgbt 0]
[1 rgbt 1]
scale <10,1,1>*.1
// Function that takes the above and turns it into a radial pattern.
#declare pig =
pigment
function { funct(sqrt(x*x+z*z), y, atan2(z,x)) }
// The streaks pigment is the radial pigment above, but only in the region
down at a - 45 degree
// angle.
#declare streaks =
pigment
radial
pigment_map
[0 rgbt 1]
[0.120 rgbt 1 ]
[.13 pig ]
[.38 pig ]
[0.39 rgbt 1 ]
[0.5 rgbt 1]
// Turn it into a function
#declare streak_func =
function
pigment { streaks }
// Make the streak function fall faster as it gets further away by modifying
the z.
#declare falling_streaks =
pigment
function { 1- streak_func(x, y, sqrt(z)*z/abs(z)) }
Cause it to fade as it get further down.
#declare Fading_falling_streaks =
pigment
gradient z
pigment_map
[0 falling_streaks ]
[.5 rgbt 0]
[1 rgbt 0]
scale <1,1,10>
turbulence .3
warp { reset_children }
// Experiment. Comment out lines to see patternas it develops.
plane
y, 0
// texture { streaks}
// texture { falling_streaks}
texture { Fading_falling_streaks}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
