POV-Ray : Newsgroups : povray.general : What does the UV in uv_mapping stand for? Server Time
25 Mar 2026 07:35:04 EDT (-0400)
  What does the UV in uv_mapping stand for? (Message 1 to 6 of 6)
Subject: What does the UV in uv_mapping stand for?
Date: 8 Mar 2001 12:24:00
Message: <3aa7c030@news.povray.org>
Hi all,
Just wondering what the "UV" in uv_mapping stands for?
Ultra-violet?
Upper Volumetrics?
Under valued?
Utter vagueness?
Thanks
Subject: Re: What does the UV in uv_mapping stand for?
Date: 8 Mar 2001 12:43:35
Message: <3AA7C4E5.DFE1D79B@aetec.ee>
Reuben Pearse wrote:
> Hi all,
To put it bluntly: UV surface is parametric surface, which is decribed
as function of 2 parameters: u and v. I.e. each point on surface is
calculated as result of some function:
x=fx(u,v);
y=fy(u,v);
z=fz(u,v);
usually u and v run from 0 to 1 (but they could take other values as
well). Put u and v values to functions and you can calculate each point
on surface.
Date: 8 Mar 2001 16:30:37
Message: <3aa7f9fd$1@news.povray.org>
They aren't the initials of any particular words.
My guess is that they were just taken from the alphabet.
They describe coordinates in a curved 2D space.
The letters were chosen by moving from z toward a.
Since x, y and z have been used, for the standard 3D
coordinates, someone decided upon u and v. Don't know
what dimension w is used for...
z,y,x,(w),u,v,
Harold
"Reuben Pearse" <reu### [at] presence-systemscom> wrote in message
news:3aa7c030@news.povray.org...
> Hi all,
> Ultra-violet?
> Upper Volumetrics?
> Under valued?
> Utter vagueness?
> Thanks
Date: 8 Mar 2001 16:49:18
Message: <slrn9afvj1.96l.ron.parker@fwi.com>
It's the parametric mapping equivalent of z, just as u and v are the
parametric mapping equivalents of x and y.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 9 Mar 2001 00:11:14
Message: <3AA86576.D26DD409@faricy.net>
> on surface.
Nah, usually 0 to 2pi ;)
Date: 9 Mar 2001 08:47:05
Message: <3AA8DF56.710C0DCC@simberon.com>
> z,y,x,(w),u,v,
Vectors in computer graphics are often represented with 4 coordinates -
w, x, y, and z.  This allows you to have a 4x4 transformation matrix
that can not only rotate and scale the coordinates but also perform
translations and perspective projections.  The resulting 4D vector
[w,x,y,z] must be transformed into the 3D vector [x/w, y/w, z/w].  All
this to say that the 'w' was reserved.
David  Buck
dav### [at] simberoncom
