POV-Ray : Newsgroups : povray.general : 2D Proximity Server Time
26 May 2026 10:07:15 EDT (-0400)
  2D Proximity (Message 1 to 4 of 4)
Subject: 2D Proximity
Date: 29 Dec 2000 05:45:14
Message: <3a4c6b3a@news.povray.org>
I have experimented with using heightfields to make smooth text. In a 2D
program I make some white text on a black background and then I blur it. The
problem is that the text becomes smooth not only in the depth direction; the
outline becomes smooth too, which is not good.
I think instead of blurring the text I need to use some kind of proximity
function on it. However, I don't know how to do it. MegaPov's proximity
pattern is too slow and grainy. Is there any freeware program that can do
what I need, or is there any special method I can use?
(I also experimented with using blobs for the smooth text, but it had the
same problem.)
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated December 17)
/ Also visit http://www.povrayusers.org
Subject: Re: 2D Proximity
Date: 29 Dec 2000 06:26:09
Message: <Xns901977C2Aseed7@povray.org>
>function on it.
look for the "level connector" at http://www.kivisalo.net/
Ingo
Date: 29 Dec 2000 11:54:39
Message: <3a4cc1cf@news.povray.org>
Thanks! Indeed a useful utility!
Rune
Date: 30 Dec 2000 00:57:36
Message: <3a4d7950@news.povray.org>
Rune, the other way of doing this is create the text as a selection, expand
the selection, fill it with white, deselect, and then blur.  Then add the
original text back over the top.  This will give you a hard edge for the
front surface (which will allow you to retain the outline of the text), and
also a bevel fall off.
Hope this helps.
Lance.
http://come.to/the.zone
