POV-Ray : Newsgroups : povray.general : eval_pigment and uv_mapping? Server Time
2 Feb 2026 02:34:50 EST (-0500)
  eval_pigment and uv_mapping? (Message 1 to 4 of 4)
Subject: eval_pigment and uv_mapping?
Date: 30 Nov 2003 15:20:34
Message: <3FCA5FC5.B23D7467@gmx.de>
High!
While testing my new "greypat2mesh" macro with various pigment pattern,
I had to notice the eval_pigment obviously doesn't allow the use of
uv_mapping with the pigment to be evaluated - I alway get the error
message "The 'uv_mapping' pattern cannot be used as part of a pigment
function!". Strange... because uv_mapping is rather a pattern modifier
than a pattern itself!
Is there a way to work this around and avoid the ugly distortions when
using a pattern on a sphere without uv_mapping for the mesh calculation?
See you in Khyberspace!
Yadgar
Subject: Re: eval_pigment and uv_mapping?
Date: 30 Nov 2003 16:02:04
Message: <k72q91-6ov.ln1@triton.imagico.de>
> High!
This is not really correct, uv-mapping is a way to map a pattern on an
object surface.  Naturally eval_pigment() (or pigment/pattern functions
in general) can't make use of it in any way.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 30 Nov 2003 17:51:27
Message: <3FCA8324.D3FB307B@gmx.de>
High!
What are the underlying (mathematical?) reasons for this behaviour?
Yadgar
Date: 30 Nov 2003 19:36:29
Message: <cjameshuff-6F10EF.19354130112003@netplex.aussie.org>
In article <3FCA8324.D3FB307B@gmx.de>,
UV-mapping maps a texture to a surface using the UV coordinates of the
evaluated point on that surface. Without a surface, there are no UV
coordinates, and thus no UV mapping. Similarly, the slope pattern only
works when applied to a surface.
http://tag.povray.org/
