POV-Ray : Newsgroups : povray.general : Heightfield of Afghanistan? Server Time
11 Nov 2025 00:49:59 EST (-0500)
  Heightfield of Afghanistan? (Message 1 to 5 of 5)
Subject: Heightfield of Afghanistan?
Date: 4 Mar 2003 17:47:41
Message: <3E653D4F.AB872204@tiscalinet.de>
High!
As some of you here around may know, I'm striving for a "PoVghanistan"
since several years... that means firstly, I'm looking for a decent
heightfield of the country to model its topography. After some search,
I've fond that gorgeous 21600 by 10800 pixel 8 bit-greyscale map of
Earth (in simple cylindrical projection), cut out Afghanistan and its
close neighbourhood - but at only 2 kms per pixel, the whole thing has
to be greatly exaggerated in height, it's far from looking realistic.
Meanwhile, I started scanning topographic maps from the 1970s at
1:300.000 scale... extracting their 25 ... 50 ... 100 metre-interval
contour lines manually is cumbersome work, not to mention interpolating
the height levels in between. I calculated that, working 8 hours each
day, 7 days a week on this titanic heightfield task, I'll be finished
with entire Afghanistan by 2098 - unless I find a way to automatize the
interpolation process!
Is there any way to obtain publicly accessible elevation data
(preferably 16bit) of Afghanistan at a higher resolution than the 30"
DEMs (perhaps like the 3" USA DEMs with about 100 m/pixel)?
See you in Khyberspace!
Yadgar
Subject: Re: Heightfield of Afghanistan?
Date: 4 Mar 2003 19:33:04
Message: <3e6545c0@news.povray.org>
I've been doing the same thing for a place near where I live, and was going
to ask the same question - whats the easiest way to make a heightfield from
a contour map?
jim
Date: 4 Mar 2003 22:34:52
Message: <3e65705c@news.povray.org>
James and Yadgar,
     I just had an idea for making height fields from contour maps.  You
could scan the maps, then use a paint program such as photoshop to create
gradations.  You would have to create a pallete with a different shade of
gray for each height interval.  You could then select the section to be
shaded using a magic wand tool, expand the selection by a bit to overlap the
lines, and fill it in with the corresponding tone on a separate layer.
After they are all filled you could use a median filter to blend the
gradation together to get a continuous surface.  This process would go
faster on a flatter landscape of course, like where I live in the midwest.
I could see this taking a few days for a 10000x10000 pixel, several square
kilometer map, not years like Yadgar was projecting for his method.  This
might speed the process up a bit, but as far as automation, I just don't
know.  If you aren't afraid of a little tedium, I say go for it.
-Ben Scheele
"James Taylor" <jim### [at] blueyondercouk> wrote in message
news:3e6545c0@news.povray.org...
going
from
> a contour map?
> jim
Date: 5 Mar 2003 02:57:20
Message: <3E65ADE0.F6D91411@gmx.de>
> a contour map?
This matter has been discussed before, see:
Subject: Topographic map to height field?
Date: Fri, 01 Mar 2002 08:36:01 -0500
From: "Timothy R. Cook" <tim### [at] scifi-fantasycom>
Organization: Bellsouth
Newsgroups: povray.general
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 18 Mar 2003 05:40:57
Message: <20030318214840.38b6728d.wvwxyz@dimension100.com>
Bah I lost all my bookmarks, but there are very much higher resolutions available
freely on the net. You just have to keep looking. I remember seeing 100m resolution
for USA. Something less than that for ROTW. Some people even have cloud maps.
Lucky really that I can't tell you the URL, it would make it too easy ;)
Simeon
On Tue, 04 Mar 2003 23:57:03 +0000
Yadgar <yad### [at] tiscalinetde> wrote:
> High!
> Yadgar
