POV-Ray : Newsgroups : povray.general : Continue trace... Insight please Server Time
16 Jul 2026 12:47:37 EDT (-0400)
  Continue trace... Insight please (Message 1 to 10 of 17)
Subject: Continue trace... Insight please
Date: 1 May 2002 07:48:53
Message: <3CCFD5F5.EE9B7695@gmx.de>
I was wondering:
How does POV-Ray know where to continue a trace?
I've looked through the rerun INIs and the pvengine.ini,
but to no avail. Does POV-Ray just look at the image
already traced, or what?
I'm just wondering because I have a major trace going
on, and wanted to use a second instance of POV to
work on some other stuff. But if I cannot get POV
to afterwords continue the major trace (cause I
reboot every now and then to clean the RAM and
SWAP-File) for sure, the risk is to high.
I'm not sure, Thorsten, Christoph? Anybody know
how to make sure it will work (like copying a bunch
of files, which I later replace), or does POV save the
Data somewhere only when the trace is being ended?
Ah, just a bunch of questions. I'll just hope that someone
can give me a working example, I don't want to ruin
anything, because the major trace is under time-pressure...
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Continue trace... Insight please
Date: 1 May 2002 07:57:14
Message: <3ccfd81a@news.povray.org>
In article <3CCFD5F5.EE9B7695@gmx.de> , Tim Nikias <tim### [at] gmxde>  wrote:
Yes, it looks at the image file.  How exactly it is done depends to some
extend on the image format used.  Also note that continue trace is not
supported for all image formats as noted in the docs somewhere.
    Thorsten
e-mail: tho### [at] trfde
Date: 1 May 2002 09:31:32
Message: <3CCFEE01.ED9DD119@gmx.de>
Hm. So, is it for BMP? I couldn't find that,
just this:
"Some image formats (namely TGA and PNG) also
store information about where the file started..."
The image is already tracing a couple a days, and it looks
like another one to go, but I'm getting impatient on other
projects... I didn't use the Create_Ini option, so
I guess that's too late now, right?
Another thing: The render-menu has this rerun-entry.
I can select which files to rerun, and if I want to
continue the latest file.
If I use a second instance of POV, I gather that
POV will overwrite the "last scene traced" info.
Any way to restore POV to think that another file
needs to be continued? Continue did work for
BMP until now, so I guess the problem is just
to have POV think which file to continue.
Thanks for your help!
Tim Nikias
Date: 1 May 2002 10:01:47
Message: <3CCFF54F.3802D455@kh.rim.or.jp>
Dear
You must check a povray.c.
Y.Tanabe
Kobe,Japan
 #ifdef df3OuputPatch
   // disable continue trace if df3 output selected
   if(opts.OutputFormat == 'd' || opts.OutputFormat == 'D')
     if(opts.Options & CONTINUE_TRACE)
        Warning(0.0,"Disabling continue-trace");
        opts.Options &= ~CONTINUE_TRACE;
 #endif
   if((opts.Options & DISKWRITE) && (opts.Options & CONTINUE_TRACE))
     Read_Rendered_Part(Actual_Output_Name);
     if(opts.Last_Line > Frame.Screen_Height)
        opts.Last_Line = Frame.Screen_Height;
     if(opts.Last_Column > Frame.Screen_Width)
        opts.Last_Column = Frame.Screen_Width;
      Stage = STAGE_CONTINUING;
if(Open_File(Output_File_Handle,Actual_Output_Name,&Frame.Screen_Width,&Frame.Screen_Height,Buffer_Size,READ_MODE)
!= 1)
        Close_File(Output_File_Handle);
        Warning(0,"\nError opening continue trace output file.\n");
        Warning(0,"Opening new output file %s.\n",Actual_Output_Name);
        /* Turn off continue trace */
if(Open_File(Output_File_Handle,Actual_Output_Name,&Frame.Screen_Width,&Frame.Screen_Height,Buffer_Size,WRITE_MODE)
!= 1)
          Error("Error opening output file.");
       // CHANGEFILETYPE
    else
!= 1)
      //CHANGEFILETYPE
> just this:
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 1 May 2002 10:36:58
Message: <3CCFFD59.6FD0403E@gmx.de>
Hm. povray.c?
You're talking about source-code there.
Though its nice of you to comment on that,
but I was merely asking where POV-Ray
saves its knowledge which file it has
traced recently, so that I can overwrite
newer data to use an other image to
check for continue-trace.
But someone will probably learn something
from that, though its not me! ;-)
"Y.Tanabe" wrote:
> Dear
> Y.Tanabe
> Kobe,Japan
>  #endif
!= 1)
!= 1)
>        // CHANGEFILETYPE
>     else
!= 1)
>       //CHANGEFILETYPE
Tim Nikias
Date: 1 May 2002 11:08:06
Message: <3cd004d6@news.povray.org>
In article <3CCFFD59.6FD0403E@gmx.de> , Tim Nikias <tim### [at] gmxde>  wrote:
> traced recently,
Read about the "Resuming Options" in the documentation.  It has nothing to do
with the information stored by the GUI frontend for your convenience.  You can
always use the direct command line option to continue any file at any time as
long as it is one of the supported formats.  BMP is one of them.
    Thorsten
Date: 1 May 2002 12:13:45
Message: <3CD01407.72E4782B@gmx.de>
I searched for "continue" (as in continue trace), didn't
think about "resume"...
Thank you very much!
>     Thorsten
Tim Nikias
Date: 1 May 2002 12:18:41
Message: <3cd01561@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message news:3CCFEE01.ED9DD119@gmx.de...
Yes. When the BMP is created, a 'magic number' is written to the start of each
line. The continue trace code uses that to determine if the line has been over-
written by the renderer yet.
-- Chris
Date: 1 May 2002 19:45:41
Message: <3CD07DF5.2A84B88A@gmx.de>
So, if I actually just copy the image, do all kinds of different work,
then let POV-Ray use a given INI-File to check for the
copied image with a given scene-file, it will go on from there?
Coool. Way cool.
> -- Chris
Tim Nikias
Date: 2 May 2002 03:46:36
Message: <3cd0eedc@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message news:3CD07DF5.2A84B88A@gmx.de...
> then let POV-Ray use a given INI-File to check for the copied image
provided you are using the same height and width, yes.
-- Chris
