![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
there are a few beautiful models (pointed out by ken in
an earlier post) at:
http://www-graphics.stanford.edu/data/3Dscanrep/
does anybody know what their "range" models are? they
talk about the range models as opposed to 3D models, but
i can't make any sense of it.
the reason i'm asking is cuz i really liked the buddha and
dragon they have, but i don't know if the zipped "range"
files they have would fly in pov.
thank you, miker
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3cacae79$1@news.povray.org>, "ZSpider" <zsp### [at] gte net>
I'm guessing a "range scanner" is a device that determines the distance
to the surface of an object from a certain point or points, allowing it
to get points on the surface of the object...sort of like real-world
raytracing. The range image is like a depth buffer from a camera that
wraps around the scene.
It looks like these files are provided for people doing research in
surface reconstruction algorithms who don't have access to a scanner. In
other words, these are not models, but raw data to be used to generate
models. They would be fairly useless for POV.
Most of them have reconstructions available, these look like some kind
of mesh format, maybe VRML (the tool they used is called vrip). Some of
them have reconstructions in other formats...the Happy Buddha and Dragon
are in Inventor, VRML, and QSplat.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
range data=height_field
ply=mesh
I made ply2mesh2 converter. Tested it on the buddha.
http://luxlab.com/tmp/buddha.zip
Use like this:
global_settings{assumed_gamma 1}
location <0,0.5,-4>
direction 1.8*z
look_at <0,0,0>
light_source{<30,-30,-10> rgb<0.3,0.5,1>*0.4}
light_source{<-30,30,-30> rgb<1,0.7,0.2>}
#include "buddha.inc"
object{Buddha pigment{rgb 1} finish{diffuse 0.7 ambient 0}
rotate 190*y scale 10 translate -1.5*y}
_____________
Kari Kivisalo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Kari
One has to be as fast as light to download your mesh2 as you put it in a
temp folder :-)
It is no more available at the URL you gave. :-(
May we get it anywhere else?
Many thanks
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's still there. What error did you get?
_____________
Kari Kivisalo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The range scanners I am familiar with use a laser to determine distance.
The basic concept can be constructed using a simple range finder (I believe
hunters use these) mounted on a 2 axis mount. The more expensive versions
are automated and more precise, they are capable of collecting millions of
points in minutes. The resulting data is like having a sphere with a grid
on it - each grid cell has a range. Now you have spherical coordinates for
all points seen by the scanner - easily converted to rectangular coordinates
and aligned with other scans. The data for each cell can include intensity
(even for seperate channels of RGB for color!)
The data collected is like have a completly dark scene with a single point
light (no radiosity please :-). The areas that are *lit* are the areas that
will be scanned up to the range limit and object reflectivity requirements
of the of the scanner.
You are right - just points have limited use directly in POV, but the number
of things that can be done with the points is limitless. Most don't require
special knowledge, just creativity:
Using spheres for each of the points one can re-create the scene. By
controling the size of the spheres the *looks* of the scene can be easily
adjusted. This method can produce from fairly decent images. If available,
intensity or color could be added to each shpere giving a better image.
The data could be used to generate a height field for terrain generation
(I've done this with an entire open pit coal mine).
A mesh can be created from the points giving an actual surface.
This is just a small spattering of what I have managed to do with point
clouds and POV.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
3cacae79$1@news.povray.org...
Note that these models were converted by Mael to povray not so long ago:
http://news.povray.org/3ba8aae0@news.povray.org
http://news.povray.org/3ba8ae27@news.povray.org
He also did some interesting tests of subsurface scattering and patina with
them.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
