POV-Ray : Newsgroups : povray.general : I am calculating a normal... Server Time
30 Dec 2025 01:44:04 EST (-0500)
  I am calculating a normal... (Message 1 to 6 of 6)
Subject: I am calculating a normal...
Date: 27 Feb 2002 23:29:42
Message: <3C7DB22D.2000107@aol.com>
and my calculation returns the following values:
< -1.#IND000,-1.#IND000,-1.#IND000 >
can anyone help me make sense of this?
Bottom line, I just need to know how to test for these and give them a
skip when they occur.
Subject: Re: I am calculating a normal...
Date: 28 Feb 2002 00:41:20
Message: <3c7dc300@news.povray.org>
Jim Charter wrote in message <3C7### [at] aolcom>...
Without seeing the code you are using, I can't tell you for certain.
 The -1.#IND means that a recent calculation had an undefined result.  I'm
guessing you're dividing by zero somewhere.  Do your calculations normalize
the vector?
Mark
Date: 28 Feb 2002 05:47:02
Message: <3C7E0AA1.4050903@aol.com>
> the vector?
> Mark
 Thanks Mark, as it turns out it is not really a show stopper
I tested:  #if ( Norm.x = -1 & Norm.y = -1 & Norm.z = -1 )
			don't use Norm
crude, I know, but good enough in this case
Date: 28 Feb 2002 05:55:14
Message: <vo2s7uc355p2c5e52bea9uva2ibjbqcndt@4ax.com>
AFAIK
-1 != -1.#IND
btw: I didn't found any place in 3.5 documentation where "#IND" is noted
and/or explained. It can confuse newbies.
ABX
Date: 28 Feb 2002 06:18:05
Message: <3c7e11ed@news.povray.org>
Skiba <abx### [at] babilonorg>  wrote:
> AFAIK
> -1 != -1.#IND
It is an artifact of the C library used.  Results may be different for
different C libraries and thus this cannot be noted in the documentation.
Further, checking for NANs and other invalid floating-point values was not
part of the C standard until C99, so many compilers don't support those recent
improvements yet.  For this reason, it remains the users' responsibility to
only feed valid input into the various floating-point calculations in order to
get valid output...
    Thorsten
e-mail: tho### [at] trfde
Date: 28 Feb 2002 16:53:51
Message: <3C7EA6E7.7010607@aol.com>
Thankyou again for the explanation.  My SDL was not well-formed and the
bad input was most likely do to sloppy loop control.  Since it happened
at the end of a loop, it was just as easy to drop the offending
calculation.
Thorsten Froehlich wrote:
> In article <vo2s7uc355p2c5e52bea9uva2ibjbqcndt@4ax.com> , W"odzimierz ABX
>>AFAIK
>>-1 != -1.#IND
> get valid output...
>     Thorsten
