POV-Ray : Newsgroups : povray.general : rotation around arbitary axis? Server Time
31 Dec 2025 22:24:03 EST (-0500)
  rotation around arbitary axis? (Message 1 to 10 of 12)
Subject: rotation around arbitary axis?
Date: 12 Feb 2002 16:36:44
Message: <3C698B4C.6030504@web.de>
When just reading a bit about quaternions and that stuff
I was wondering if I could make Pov rotate any object around an arbitary
axis (not around X,Y,Z).
This has surely been discussed before or I've just missed it in the
docs, but how is it?
Sebastian H.
Subject: Re: rotation around arbitary axis?
Date: 12 Feb 2002 16:52:36
Message: <3c698ea4$1@news.povray.org>
"Sebastian H." <seb### [at] webde> wrote in message
news:3C6### [at] webde...
    vaxis_rotate???
Date: 12 Feb 2002 17:35:13
Message: <chrishuff-04E7D0.17345612022002@netplex.aussie.org>
In article <3c698ea4$1@news.povray.org>,
 "Bill DeWitt" <bde### [at] cflrrcom> wrote:
>     vaxis_rotate???
vaxis_rotate() is a function that operates on vectors. There are a few
macros available that will generate a transform for rotating objects
around any axis (do a search on the scene file groups here, or look in
the povray.org link pages), and one is included in the POV 3.5 standard
includes.
Date: 13 Feb 2002 01:30:08
Message: <3c6a07f0$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> >     vaxis_rotate???
> includes.
    Maybe I misunderstood the question.
#declare Sphere1 = x;
#declare Sphere2 = vaxis_rotate(Sphere1, 1, 360*clock);
   sphere { Sphere1, 0.4 pigment { rgb x } } // the object
   sphere { Sphere2, 0.5 pigment { rgb y } } // the rotated object
   cylinder { 0, 1, 0.25 pigment { rgb z } } // the arbitrary axis
Date: 13 Feb 2002 03:25:35
Message: <7b8k6u09e18dl5gn1m14qk26elgu6bthmb@4ax.com>
On Tue, 12 Feb 2002 22:38:20 +0100, "Sebastian H." <seb### [at] webde> wrote:
Sure, do following steps:
1. Download, install and start current beta of 3.5
2. Write at begining of your scene
    #include "transforms.inc"
3. Call macro in object modifiers list of your object:
    Axis_Rotate_Trans(Axis, Angle)
If you not use 3.5 then look at http://enphilistor.users4.50megs.com/macs.htm
There is macro AxisRotate - afaik result is the same.
ABX
Date: 13 Feb 2002 06:46:00
Message: <3C6A5258.3070108@web.de>
> ABX
Ah, ok that is what im looking for.
Date: 13 Feb 2002 09:19:15
Message: <chrishuff-58548D.09190113022002@netplex.aussie.org>
In article <3c6a07f0$1@news.povray.org>,
Now rotate a sphere with a patterned texture. Or rotate a box, or a
julia fractal.
Vectors aren't always enough, which is why the axial rotation macro is
included with 3.5.
Date: 13 Feb 2002 13:39:36
Message: <3c6ab2e8@news.povray.org>
> julia fractal.
#declare I = 0;
#while ( I < 1 )
#declare Sphere2 = vaxis_rotate(Sphere1, 1, 360*I) ;
   // the object
   sphere { Sphere1, 0.4 pigment { checker scale .1 } }
   sphere { 0, 0.2 pigment { checker scale .1 } translate Sphere2 }
   // box rotated twice as far out
   box { -0.25, 0.25 pigment { bozo scale .1 } translate Sphere2*2 }
   cylinder { 0, 1, 0.25 pigment { rgb y } }
   // insert your own fractal here...
#declare I = I + 0.1;
Date: 13 Feb 2002 14:05:36
Message: <chrishuff-63D2E8.14052213022002@netplex.aussie.org>
In article <3c6ab2e8@news.povray.org>,
> #declare I = 0;
> #while ( I < 1 )
>    // the object
> #end
None of those are rotated at all, they all stay in their original
orientation. All translate will do is change their location. You can
make a ring of them, but you can't rotate them with vaxis_rotate().
Now, you could use vaxis_rotate together with the Reorient_Trans()
macro, but that's just making it hard for yourself...why not just use
the Axis_Rotate_Trans() macro?
Date: 13 Feb 2002 14:13:46
Message: <3c6abaea$1@news.povray.org>
> orientation.
    Then maybe I did misunderstand the question, I thought he wanted to
rotate an object -around- the axis, not rotate the -object- around an
axis.... uh... what ever that means...
