POV-Ray : Newsgroups : povray.general : POV and Quantum Mechanics? Server Time
13 Jan 2026 21:02:23 EST (-0500)
  POV and Quantum Mechanics? (Message 1 to 10 of 12)
Subject: POV and Quantum Mechanics?
Date: 12 Jan 2002 13:45:48
Message: <3C408458.962543F1@scifi-fantasy.com>
Hmm just getting to an internet connection where I can read the
POV NGs after a few days...
on the way up to Illinois for vacation, the reference to
the experiment used to test whether light is particles or
waves struck me as being interesting.
Question: Are POV photons waves, or particles? (or neither) ;)
As I don't currently have access to POV 3.5 b, I must ask
y'all to try this for me.
Construct a photon-using scene as follows:
area   wall w/1 slit in centre
light  |        |         |
*      |        |         |  white screen
                wall w/2 slits dividing wall into 3 equal parts
I predict the following possible outcomes of this render:
1) the white screen will not be illuminated at all
2) the white screen will have an interference pattern on it
3) the white screen will have two lines with fuzzy edges
4) the white screen will have two lines with sharp edges
Another question: is polarisation possible in POV?
- Tim Cook
Subject: Re: POV and Quantum Mechanics?
Date: 12 Jan 2002 16:16:12
Message: <chrishuff-11D475.16170012012002@netplex.aussie.org>
In article <3C408458.962543F1@scifi-fantasy.com>,
Particles. Simulating the wave nature would require huge amounts of
processing power...
Depending on the width of the first slit and distance of the light,
either 1 or something like 3, with the fuzzyness depending on the number
of photons you used.
No.
POV-Ray is not designed for physically correct simulation of optical
effects, it took a long time just for dispersion and photon mapping to
be added. Effects like diffraction are often difficult to implement,
very slow to compute, and would contribute little or nothing to the
majority of scenes.
Date: 13 Jan 2002 00:14:20
Message: <7329287.zxgJ6IN8Ob@3-e.net>
http://www.winosi.onlinehome.de
> light  |        |         |
> - Tim Cook
> http://empyrean.scifi-fantasy.com
Date: 14 Jan 2002 08:56:41
Message: <slrna45osr.u61.ron.parker@fwi.com>
> majority of scenes.
Polarization wouldn't be much harder to deal with than dispersion, though
birefringence might make it a little more interesting.
Note, too, that dispersion isn't perfect either.  For one thing, it
assumes that the function relating IOR to wavelength is very simple
for the visible spectrum.  For another, since it's being forced to
work with tristimulus values (RGB) instead of spectral power distributions,
it has to infer some sort of tristimulus->SPD conversion where none
exists.  If we provided a way to specify colors as SPDs this wouldn't
be such an issue, of course, but we haven't done that.  (For more on
tristimulus values, SPDs, and the pitfalls of conversion, check out
the Color FAQ at http://www.inforamp.net/~poynton/PDFs/ColorFAQ.pdf )
Daren Wilson's original dispersion patch had some support for something
approaching SPDs in the form of 12-component colors, but that support
didn't make it into 3.5.  On the other hand, his RGB->SPD conversion was
much less realistic than the one I threw together for 3.5, so hopefully
users will feel that it's balanced out at least a little.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 14 Jan 2002 13:41:03
Message: <chrishuff-4FE598.13414714012002@netplex.aussie.org>
In article <slr### [at] fwicom>,
Wouldn't you have to keep track of the amount of light polarized along
each plane? Probably with some kind of spline relating intensity of
light to angle of polarization? A lot more data for each ray...
Date: 14 Jan 2002 14:24:19
Message: <slrna46c36.b02.ron.parker@fwi.com>
Compared to what we keep track of for dispersion?  Not really.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 19 Jan 2002 16:39:32
Message: <3C49E792.62CAB2DC@scifi-fantasy.com>
> > along each plane? Probably with some kind of spline relating
> > intensity of light to angle of polarization? A lot more data
> > for each ray...
There's only 3 more values per ray for a more realistic simulation
of light; amplidude/frequency/rotation around axis of travel...?
Could probably do some interesting things with having materials
change the frequency of the light...
Speaking of something completely different...iridescence.  It's
an interference pattern between two surfaces of oil or similar,
how 'bout trying to do that the hard way in POV?  Should be
doable even in 3.1g...I think I'll play around with that and
such when I get back to my computer.
Date: 19 Jan 2002 16:53:28
Message: <chrishuff-B4817F.16542219012002@netplex.aussie.org>
In article <3C49E792.62CAB2DC@scifi-fantasy.com>,
I think you would have to store more information, a bunch of "samples"
around the axis of travel, interpolated with a spline if the
calculations need it. Ordinary light isn't polarized in a single
direction, it is a mix of photons polarized in all directions.
Frequency has more to do with color, and is a different issue. POV could
assume all photons are in the same frequency range independant of
polarization, and just store weight values specifying the percentage
polarized at each angle. The more samples, the better the accuracy, but
slower and using more memory.
There is the "irid" finish feature, which is apparently somewhat based
on reality, though not a physical simulation...
I don't know what you have in mind though...simulating the waveforms
with the onion pattern?
Date: 19 Jan 2002 17:03:28
Message: <3C49ED2D.E6961A0E@scifi-fantasy.com>
> based on reality, though not a physical simulation...
That or something similar...make two layers of patterned materials
close to each other but slightly misaligned...I've already managed
to achieve anisotropic reflection by actually modelling the finish,
so I wonder what other 'effects' I can do straight cheap-simulation
of.
Date: 19 Jan 2002 17:47:16
Message: <chrishuff-444080.17481319012002@netplex.aussie.org>
In article <3C49ED2D.E6961A0E@scifi-fantasy.com>,
> I've already managed to achieve anisotropic reflection by actually
> modelling the finish, so I wonder what other 'effects' I can do
> straight cheap-simulation of.
Details? I've done it by using averaged textures (I think Ron Parker
discovered this technique), with each texture identical except for the
normal...and a slower, older method used a very finely scaled normal and
high antialiasing.
