POV-Ray : Newsgroups : povray.general : 3.1g vs 3.5b6? Server Time
25 May 2026 07:47:51 EDT (-0400)
  3.1g vs 3.5b6? (Message 1 to 5 of 5)
Subject: 3.1g vs 3.5b6?
Date: 28 Oct 2001 22:17:54
Message: <3BDCCA11.434D75B6@scifi-fantasy.com>
Same scene.  Same settings.  Radiosity, media, the whole shebang.
3.1 took 00:04:23:51
3.5 took 00:18:56:52
Shouldn't 3.5 be at least as fast, if not faster than, 3.1?
Tim Cook
Version: 3.12
Subject: Re: 3.1g vs 3.5b6?
Date: 29 Oct 2001 01:50:18
Message: <3BDCFC29.379A08CC@gmx.de>
3.1 radiosity should not be compared to 3.5 radiosity since both are
completely different.
Date: 29 Oct 2001 03:19:53
Message: <3bdd1129@news.povray.org>
In article <3BDCFC29.379A08CC@gmx.de> , Christoph Hormann
...and thus comparing the two with radiosity is like comparing apples and
oranges.  There is simply no use to use features that are marked as
"experimental" to measure speed differences because there will always be
quality differences as well if the experimental features changes (which it
is free to do).
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 29 Oct 2001 09:47:52
Message: <3BDD6BC2.323FB33B@scifi-fantasy.com>
> both are completely different.
What are good 3.5 radiosity settings to shrink that 14-hour
render time I got?  I think all my settings were the defaults.
Tim Cook
Version: 3.12
Date: 29 Oct 2001 13:02:13
Message: <3bdd99a5@news.povray.org>
Timothy R. Cook <tim### [at] scifi-fantasycom> wrote:
: What are good 3.5 radiosity settings to shrink that 14-hour
: render time I got?  I think all my settings were the defaults.
  A good start is to put just an empty radiosity block in global settings.
That is:
global_settings
  radiosity { }
  If the result doesn't look good, you could then try increasing count (for
example to 100) and/or decreasing pretrace_end (to .02 for example).
  If it still doesn't help, then you'll have to start tweaking with other
parameters as well...
