POV-Ray : Newsgroups : povray.general : Animation-proof radiosity Server Time
24 Mar 2026 14:17:58 EDT (-0400)
  Animation-proof radiosity (Message 1 to 6 of 6)
Subject: Animation-proof radiosity
Date: 26 Oct 2001 13:07:23
Message: <3BD997FE.4AB5F800@aol.com>
In p.b.a I posted an animation where I have lighting from radiosity from
ceiling lights.
In any one scene, the radiosity is cool, but as I compile an anim, the
lighting looks like it's jumping around, almost like lightning.
The source code for the radiosity settings & room are posted there.
It used 0.7.
Subject: Re: Animation-proof radiosity
Date: 26 Oct 2001 13:12:01
Message: <3bd99961@news.povray.org>
It's a normal drawback of radiosity. Rays *jittering* is the keyword.
Yet it seems like radiosity scenes look different every time you render
them...
Jonathan.
"Greg M. Johnson" <"gregj56590[:-0]"@aol.com> ha scritto nel messaggio
news:3BD997FE.4AB5F800@aol.com...
> ceiling lights.
> It used 0.7.
Date: 26 Oct 2001 13:32:30
Message: <3bd99e2e@news.povray.org>
Hi Greg,
Have you tried saving the initial radiosity solution, then reloading it for
all subsequent frames ( with always_sample_off and a pretrace start and end
set to 1)? I tried it, and the results were perfect. Objects were moving in
my scene, though the camera was stationary. Dunno if this would make an
impact on the results.
All the best,
Andy Cocker
"Greg M. Johnson" <"gregj56590[:-0]"@aol.com> wrote in message
> ceiling lights.
> It used 0.7.
Date: 26 Oct 2001 16:45:04
Message: <3BD9CB04.7F2AED46@aol.com>
Neat idea, BUT I also want my moving character to cast shadows.  Am I right
that your suggestion would not allow this?
Date: 27 Oct 2001 21:50:54
Message: <3bdb647e@news.povray.org>
When Rad=1, my scene renders in 1 minute.
When Rad=2, it takes almost 3 minutes!
What is wrong?  Isn't it supposed to be faster?
#declare Rad = 1;
global_settings {
  assumed_gamma 1
#switch (Rad)
 #case (1)
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.02
    count 50
    error_bound 0.5
    recursion_limit 1
    save_file "Filename.rca"
 #break
 #case (2)
  radiosity {
    pretrace_start 1
    pretrace_end   1
    always_sample off
    load_file "Filename.rca"
 #break
Andy Cocker <big### [at] mariner9fsnetcouk> wrote in message
for
end
in
Date: 28 Oct 2001 04:58:05
Message: <3bdbd6ad@news.povray.org>
Well, you're using fairly low settings. Try with very high radiosity
settings and see if it isn't faster.
Jonathan.
"Anthony D'Agostino" <sco### [at] spamEcsicom> ha scritto nel messaggio
news:3bdb647e@news.povray.org...
> #declare Rad = 1;
> global_settings {
>   assumed_gamma 1
> #switch (Rad)
>  #case (1)
>   radiosity {
>     pretrace_start 0.08
>     pretrace_end   0.02
>     count 50
>     error_bound 0.5
>     recursion_limit 1
>  #break
>  #case (2)
>   radiosity {
>     pretrace_start 1
>     pretrace_end   1
>     always_sample off
>  #break
> #end
> for
> end
> in
