POV-Ray : Newsgroups : povray.general : POV 3.5 documentation Server Time
11 Sep 2025 15:21:46 EDT (-0400)
  POV 3.5 documentation (Message 1 to 7 of 7)
Subject: POV 3.5 documentation
Date: 14 Sep 2001 09:44:11
Message: <3BA2097E.D0AB65A1@ief.u-psud.fr>
Hi all,
I'm using UNIX or ATARI platforms, and beta 3.5 are not yet released.
I must precise that I compiled 3.1g unofficial version for ATARI, and
that it is available on my home page. I used a modified version of 3.1g
a 2D Graph Describer, and 3D modeller of explicit mathematical surfaces.
In my software, I export scripts from 3.1 version of POVRAY as you can
see on "http://eureka.atari.org/vrml" link. It seems that POVRAY 3.5
has a completely new manner to handle 3D explicit surfaces. I used to
define a "mesh" containing an explicit formula of the explicit surface,
and describing the vertex and it's normals, computed from the surface's
definition. That produced a really long parsing, due to the definition
of
macros for the points, and the normals.
As I suspect, the explicit formula of 3D surfaces is now sufficient to
define a 3D shape. Am I wrong ? If not, I would really appreciate to
read the 3.5 documentation about that topic. Is there any online
documentation available on the WEB ? I really look forward to read it.
Thanks for your help,
Best regards,
mailto:lec### [at] atariorg
Subject: Re: POV 3.5 documentation
Date: 14 Sep 2001 09:52:42
Message: <3BA20CA8.DD86D21C@pacbell.net>
The POV-Ray v3.5 documentation will not be released into a single download
format until the beta rounds are over. The documentation is changing quite
frequently at this time and the POV-Team will not release single copies of
it, as a seperate download, until the docs have been finalized.
Ken Tyler - POV-Ray Technical Assistance Group
Date: 14 Sep 2001 14:12:23
Message: <Xns911CCD8CACDE3seed7@povray.org>
in news:3BA2097E.D0AB65A1@ief.u-psud.fr Francois Le_Coat/mailaxis
wrote:
>  I used to
> surface, and describing the vertex and it's normals, computed from
> the surface's definition. That produced a really long parsing, due
> to the definition of
> to define a 3D shape.
 POV-Ray 3.5 has the parametric{} object, that directly renders the
formula. But it can be very slow in its current state.
 Incidentally I have yesterday posted a macro that may be of interest
for you, as it calulates the mesh a lot faster than the output of your
program does. It uses mesh2 and function, both new in 3.5, see:
Newsgroups: povray.binaries.scene-files
Subject: Re: param.inc
Message-ID: <Xns### [at] povrayorg>
Date: 14 Sep 2001 04:31:21 -0400
Xref: news.povray.org povray.binaries.scene-files:2438
Ingo
Date: 14 Sep 2001 15:09:24
Message: <3ba255e4@news.povray.org>
In article <3BA20CA8.DD86D21C@pacbell.net> , Ken <tyl### [at] pacbellnet>
While Ken is absolutely correct with this, you can view it it online at
<http://www.povray.org/working-docs/>
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 17 Sep 2001 10:13:10
Message: <3BA604C4.55D6A689@ief.u-psud.fr>
Thank you ! That's a really interesting piece of script. I may use
agree ? Anyway, do you think that it may also work with MegaPov 0.7 ?
In this case, waiting for Povray 3.5 UNIX/Linux code release, I
may compile MegaPov for my ATARI (I'm on the way), and test your
scripts. Meanwhile I realized that MegaPov 0.7 parametric surfaces
are really slow to render, and very fast to parse. It's the exact
great miss from MegaPov 0.7, and Povray 3.5 (I suspect), that there's
no cylindrical or spherical coordinates. It seems to be possible
to do with your proper script. So thanks again !
> wrote:
> >  I used to
> From: ingo <ing### [at] homenl>
Date: 17 Sep 2001 10:19:01
Message: <3BA60623.5D917857@ief.u-psud.fr>
Hi Thorsten,
That's a very useful link. We won't have a Povray code release soon, but
we can have a preview of the features now. That's very kind of you.
Best Regards,
>     Thorsten
> Thorsten Froehlich
Date: 17 Sep 2001 16:39:24
Message: <Xns911FE6794E3BCseed7@povray.org>
in news:3BA604C4.55D6A689@ief.u-psud.fr Francois Le_Coat/mailaxis
> agree ?
Yes, go ahead.
You probably have to make a few changes then:
The RangeMM function has to changed into a macro.
If you use macros to build the functions it should work
If you use MegaPov functions you'll probably have to change a few
things.
Ingo
