POV-Ray : Newsgroups : povray.general : pov-file-import to moray Server Time
23 Jan 2026 00:34:23 EST (-0500)
  pov-file-import to moray (Message 1 to 5 of 5)
Subject: pov-file-import to moray
Date: 12 May 2001 03:37:14
Message: <3AFCE8B7.800F9EAA@gmx.de>
Sorry, that I post in this group, but in there isn't any traffic in the
moray group.
I want to render different objects like cylinders and cones. I calculate
the coordinates and radi with a third hand software and I'm write a
pov-file. For better adjusting the whole scene (camera-position,
light-position..) I want to import these objects into moray but do not
know how. Can you help me ?
Thanks a lot
Subject: Re: pov-file-import to moray
Date: 12 May 2001 07:21:09
Message: <3AFD1DAB.EA4F5AB1@erols.com>
> the moray group.
> calculate
> Thanks a lot
Pick a rough shape (a big box, or a small number of them) that hold(s) everything in
your scene,
and use Moray to build those same
objects.  Then adjust the camera the way you want.
Export the resulting Moray scene.  You'll have your camera statement
then.
Hope this helps,
John
ICQ: 46085459
Date: 12 May 2001 07:58:43
Message: <3AFD25FF.4D6F06DE@gmx.de>
Thank you for your help, but I tried this before. It is not good enough.
I want to display a vector-field in a complicated geometry and in the future in
addition to the
vectors lots of  tubes along splines (sphere-sweep..?). The data come from a separate
software . So
you really have to see all the objects to decide if the camera-position and the lights
are ok.
Date: 12 May 2001 10:38:14
Message: <3afd4ad6@news.povray.org>
> moray group.
we're all just lurking...
PGP Public Key
Date: 14 May 2001 13:12:35
Message: <MPG.1569dc257f71b5fb989685@news.povray.org>
In article <3AFCE8B7.800F9EAA@gmx.de>, uth### [at] gmxde says...
> moray group.
I don't think there is a way to go from POV to Moray. Just from
Moray to POV.
http://www.crosswinds.net/~robertsc30/
Free HLP files for: Access 97 object reference. Plus lots of
freeware, 500+ files.
Help in the cure for leukemia by using Peer-to-peer computing.
http://www.intel.com/cure
