#local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
#macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
I had to do it; it's a compulsion. Doesn't anyone understand?
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B) polygon{
4,A,A+z,B+z,B texture{pigment{color rgb 1}finish{ambient 1}}}
#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,b+c)P(b+
c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}//FL
or
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
which has the advantage of rendering without warnings.
#local R=<7084844682857967,32787982,826975826580>#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Francois Labreque <fla### [at] videotronca> wrote:
: #local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
: #macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
: {ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
: d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
I don't understand what does it do, but it can ne made a lot shorter:
#local a=x+y;#local b=a+x;#local c=a+b;#local d=b+c;#macro P(A,B)polygon{
5,A,A+z,B+z,B,A pigment{rgb 9}}#end P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P
(2*b,d)P(d,<2,3,0>)camera{location <5,1.2,-5>look_at a orthographic}//FL
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Ron Parker <ron### [at] povrayorg> wrote:
: #local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
: texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
: (2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
Darn, you made it first.
However, my version is shorter :)
And doesn't warn either.
Yes, I like the rgb 9 trick. That one's new to me. And of course the
'texture' keyword is almost always redundant.
The ,0 is unnecessary, as is the space after location.
So can you make my new one smaller?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z} // Only my opinions
Okay, that one was boring. So's this one, but at least the output is pretty.
plane{z 3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate z
*60#local a=a-1;#end translate-15*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{-9blue 1scale-x-y+z}text{ttf
"arial.ttf""RP".01,0translate-<.6,.4,.02>}light_source{-z*3rgb-.2} // Ron Parker
And now: the warning-free version.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
That looks like fun! So I made my own. I'm sure it can be shortened more
than this, but 4 lines ain't bad :)
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare
B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end
M(<4,0>)
L(<8,8>)L(<2,8>)M(<6,0>)L(<10,8>)L(<16,8>)M(<8,4>)L(<12,4>)camera{location
<9,4,-15>}sky_sphere{pigment{bozo colour_map{[0 rgb 0][1 rgb 1]}}} // Tek
> B=A;
> M(<4,0>)
Doh! It wrapped wrong! Can anyone explain what's going on with that? When I
wrote it it wasn't wrapping like that :(
Tek
http://www.evilsuperbrain.com
I think I've fixed it now... I hope...
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end M(<4,0>)
