POV-Ray : Newsgroups : povray.general : My turn! Server Time
20 Jun 2026 09:15:36 EDT (-0400)
  My turn! (Message 1 to 10 of 42)
Subject: My turn!
Date: 8 May 2001 11:01:52
Message: <3AF80917.FF2B40DB@videotron.ca>
#local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
#macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
Subject: Re: My turn!
Date: 8 May 2001 11:16:10
Message: <slrn9fg3dv.ik2.ron.parker@fwi.com>
I had to do it; it's a compulsion. Doesn't anyone understand?
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B) polygon{
4,A,A+z,B+z,B texture{pigment{color rgb 1}finish{ambient 1}}}
#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,b+c)P(b+
c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}//FL
or
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
which has the advantage of rendering without warnings.
#local R=<7084844682857967,32787982,826975826580>#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 8 May 2001 11:37:27
Message: <3af812af@news.povray.org>
Francois Labreque <fla### [at] videotronca> wrote:
: #local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
: #macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
: {ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
: d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
  I don't understand what does it do, but it can ne made a lot shorter:
#local a=x+y;#local b=a+x;#local c=a+b;#local d=b+c;#macro P(A,B)polygon{
5,A,A+z,B+z,B,A pigment{rgb 9}}#end P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P
(2*b,d)P(d,<2,3,0>)camera{location <5,1.2,-5>look_at a orthographic}//FL
Date: 8 May 2001 11:45:16
Message: <3af81483@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: #local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
: texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
: (2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
  Darn, you made it first.
  However, my version is shorter :)
  And doesn't warn either.
Date: 8 May 2001 12:03:50
Message: <slrn9fg67b.ikq.ron.parker@fwi.com>
Yes, I like the rgb 9 trick.  That one's new to me.  And of course the
'texture' keyword is almost always redundant.
The ,0 is unnecessary, as is the space after location.
So can you make my new one smaller?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z} // Only my opinions
Date: 8 May 2001 16:01:26
Message: <slrn9fgk4s.itd.ron.parker@fwi.com>
Okay, that one was boring.  So's this one, but at least the output is pretty.
plane{z 3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate z
*60#local a=a-1;#end translate-15*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{-9blue 1scale-x-y+z}text{ttf
"arial.ttf""RP".01,0translate-<.6,.4,.02>}light_source{-z*3rgb-.2} // Ron Parker
Date: 8 May 2001 16:17:24
Message: <slrn9fgl2q.itd.ron.parker@fwi.com>
And now: the warning-free version.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 8 May 2001 16:21:22
Message: <3af85542@news.povray.org>
That looks like fun! So I made my own. I'm sure it can be shortened more
than this, but 4 lines ain't bad :)
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare
B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end
M(<4,0>)
L(<8,8>)L(<2,8>)M(<6,0>)L(<10,8>)L(<16,8>)M(<8,4>)L(<12,4>)camera{location
<9,4,-15>}sky_sphere{pigment{bozo colour_map{[0 rgb 0][1 rgb 1]}}} // Tek
Date: 8 May 2001 16:22:27
Message: <3af85583$1@news.povray.org>
> B=A;
> M(<4,0>)
Doh! It wrapped wrong! Can anyone explain what's going on with that? When I
wrote it it wasn't wrapping like that :(
Tek
http://www.evilsuperbrain.com
Date: 8 May 2001 16:24:32
Message: <3af85600@news.povray.org>
I think I've fixed it now... I hope...
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end M(<4,0>)
